Bad Map?
Old Jun 11, 2009 | 09:01 PM
MRZ28's Avatar
Default Bad Map?
My map is reading 92 kpa at idle and does not move from there. is the map no good, or do i have a serious Vacuume leek?
Any help is appreciated.
Thanks.
Old Jun 12, 2009 | 11:00 AM
MRZ28's Avatar
Bump, for any help.
Old Jun 12, 2009 | 01:16 PM
pdsq98gt's Avatar
What does it read when you disconnect the connector at the map? Short terminals B and C together at the MAP and it should read 5v at the pcm. Should be 0v with it disconnected. You should also have 5v on terminal C and ground at terminal B.
Old Jun 12, 2009 | 01:53 PM
jimmyblue's Avatar
Moderator
Could have just popped out the back of the intake.
Is it in there solid?
Old Jun 12, 2009 | 02:04 PM
MRZ28's Avatar
Its on a fast 92... I didnt really care for the way it fits into the intake. Its in there good, but its loose, and will swivel freely.
Old Jun 12, 2009 | 02:19 PM
brianfromhawaii's Avatar
Fast intakes do that... its strange, but it works just fine i assure you.
