High and Low Octane Tables EXPLAINED!!!
Old Nov 10, 2003 | 05:36 PM
Bink's Avatar
Default High and Low Octane Tables EXPLAINED!!!
Great explanation from the Boys Down Under (EFILive) - the LS1/6 usage of the High and Low Octane tables...They're BLENDED!!! See here...Octane Tables
FWIW.
joel
Old Nov 10, 2003 | 05:55 PM
MNC5's Avatar
FWIW.
joel
Thanks, saved some of us a lot of . I've been trying to figure out where it comes up with some of the Timing #'s in a data log that aren't in the tables.
This should be a sticky for awhile. Now I'm off to re-do my timing tables
Old Nov 10, 2003 | 08:09 PM
WicketMike's Avatar
great info!
i asked this over at ls1tuning.com also
what if both tables are 20 at the same spot, will it always be 20 degrees then?
and
what if you set the low octane number higher then the high octane table?
just seeing if they tested this aswell
thanks
Mike
Old Nov 10, 2003 | 08:38 PM
ChrisB's Avatar
Very interesting! Also much props to EFI Live for incorporating this feature so quickly!
Old Nov 10, 2003 | 08:48 PM
jformato's Avatar
good info I was wondering when someone would get some solid info on this subject.
Jeremy
Old Nov 11, 2003 | 04:39 PM
Bink's Avatar
Jeremy
^^^^^UP.
Old Nov 11, 2003 | 05:23 PM
Slowhawk's Avatar
LS1Tech Sponsor
Thats a nice explaination.I've been setting low octain tables the same as high octain,so never caught the difference.
Old Nov 11, 2003 | 07:32 PM
HumpinSS's Avatar
What i plan to do after reading that little tidbit is whatever value i scale the h octane tables by the low octane tables will get scaled by that much as well
Old Nov 17, 2003 | 08:55 PM
Bink's Avatar
FWIW.
joel
Bump^^^^^
