mail order tune
The ecu that has the tune in itwas throwing the knock codes so I took out, and stuck the stock ecu in it. Now the the car dosent throw the code , but it dose with the bottle. SO WHATS UP WITH IT HELP ME
Additionally, if you have a KS code you are losing 4 degrees at WOT as a result of it being set.
Even 29 can be 26 or 25 depending on the ECT, IAT spark reduction tables. Regardless, 29 is higher than most of us are able to run. Further, throwing spray @ an engine that's already pulling timing due to knock is not a good idea.
The stock ecu (PCM) has a less aggressive timing table, which is why there is no knock code. It is too high for the spray though.
+1 on contacting FROST.
