How to Get More TPS Volts?
Ok First of all I know there is alot of info on this,But I do Not have the Time to Read a Million posts right now.I bought my wife a 99 Trans am.It has 4.15 V @ WOT
How can I get this sucker up to 4.5V atleast?I don't think I can get enough movement out of it if I do the TPS mod.Why would it have such little power,and how much power is this actually being lost?
Thanks!
Thanks!
Thanks!
Thanks!
Check to make sure that the TB plate is all the way open during WOT. Sometimes the cable is not adjusted properly & the TB does not fully open when the gas pedal is all the way down on the floor (WOT).
Now if the throttle blade is all the way open and hitting the bumpstop and you're still only getting 4.15V, then you'll need to do the throttle stop mod. Basically you gradually grind away at the throttle bump stop on the side of the throttle body until you get exactly 4.5V.
That's our point, the throttle blade is likely not parallel. Typically, the TPS will read around 4.5 Volts when the plate is parallel (reference voltage from the PCM is 5V). So, we are suggesting that the position of the plate be checked, in order to see whether or not it is parallel. If the OP confirms that the plate is parallel @ 4.14 Volts & there are no codes "CEL," then it is OK. It is likely that the OP will find that the plate is not parallel @ WOT. There's nothing more to say until the OP replies.
LS1-450 this was correct ,The Blade was not parallel when at 100% WOT.I did the TB Bump Stop and now we have 4.55v @ WOT.I Also have to adjust the Throttle Cable but Where do you Do that?I moved the throttle cable bracket for a temp fix to get tb to fully open @ wot.
