What else would cause shortshifting intermittently?
The car also feels a little sluggish during this. What else can I look for?
is there anything I can check or any certain values to look for? the car runs "fine" just feels down on power, shifts too early, and shifts sloppy on the 2-3 (1-2 gets firmer when its running right, but its still firm in crap mode too)
I do know my maf is peaking at 35-36 lbs/min when its running bad and hitting 38-41 lbs/min when its running better. But I can't tell if the readings are higher because the rpms are where they should be or because of a fault somewhere. Guess I can manually hold gear and see what it reads. I tried a different maf with no change.
maf is peaking right before the shift, wherever it decides to occur at that particular run (if transmission shifts at 5800, peaks at 5800...if shifts at 6100, peaks at 6100)
The cam was loping hard, the idle was really crisp, had that nice high compression "pop" sound to it. When it's running normal (aka poorly) it sounds a lot more lifeless.
This was not something I was looking for either, I just started the car and was like "damn that sounds a lot different" then down the road realized it was running a ton better at part throttle so I got on it and it ran like a bat outta hell and my tach was hitting 6200 instead of 5800 on the 1-2 shift and a little more on the 2-3.
then you are "in violation" in the moment, though
there is something like a 10-second timeout before
a code will set. Meanwhile the PCM does its self-
protection thing, short-shifting trans, maybe also
being conservative on other things.
If you are marginal, like 4.73V on a good day and
4.76V with ignition noise, there's your intermittent.
this strikes me as odd, maybe it will help...but like I said I have replaced the tps sensor before and when logging runs I've been trying to push as hard as possible to make sure it hit 100% the whole run
Ok so I had just changed these numbers the other day, today I maxed them out and dropped the lower one in half.
It seems to have worked, car feels a good 15-20hp stronger and will shift where I set it. So unless it decides to go to **** on me again tomorrow I think I found the problem.
So what does this mean? Why does this happen? (I really want to learn "why" not just "what" since I plan to do my own tuning in the future).
I noticed the minimum number of occurences for this before throwing a code was set to 150. I dropped it to 20. I guess this is why I never had a code come up (my battery has been off and on several times for various reasons and lately I've been pcm flashing like a drunk bitch at mardi gras)
Thank you very very very much. I can't tell you how happy I will be if it stays running correctly.
If I come home with a 7 second slip or break 89mph at the track tomorrow I'd like to buy you beer or 2 haha
