Cheapest programmer for gear changes?
Old Jul 4, 2009 | 11:08 AM
Intercooler2's Avatar
Default Cheapest programmer for gear changes?
I won't be ready for a bit to head in for a tune but will be swapping to a 9" with 3.70's on the 25th. What can be used to change the setting for the 3.70 gears at the cheapest cost? If it has a feature to eliminate the two codes you get with a stall change that would be a plus! For now I have just been clearing them with an OBDII scanner. I can deal with those until I get tuned.
Reason I ask is I would like to go one time to the track before the head/cam/intake swap to see what it runs with the 9" and 3.70's. See if I can hit the 11's.
Old Jul 10, 2009 | 01:12 PM
Any suggestions?
Old Jul 10, 2009 | 01:14 PM
jmm98LS1's Avatar
Cheapest option would probably be to find someone local with tuning software.....
Old Jul 10, 2009 | 05:47 PM
poconojoe's Avatar
How far are you from Glen Burnie?
Old Jul 12, 2009 | 10:01 PM
Sunset01TA's Avatar
I have a super chips hand held for you.
You can do alot more then gears.
100 bucks plus shipping.
http://www.vichubbard.com/auto-part-...r-gm-2725.html
Old Jul 13, 2009 | 02:53 PM
Mike@Diablosport's Avatar
LS1Tech Sponsor
A Predator would be a great option.
You could set the gears, do some tuning, read/clear codes, and if you need a custom tune to disable some codes, i can do that for you via email.
Thanks
Mike
Old Jul 13, 2009 | 03:34 PM
Sunset01TA's Avatar
Posted a link with the one I have
