Testing knock sensors?
Old Jul 8, 2009 | 02:16 AM
pHEnomIC's Avatar
Default Testing knock sensors?
Any good way to test if your knock sensors are working in a safe/effective manner with hptuners or somehting? I relocated my knock sensors on my 404 and been driving it but i havent seen a single degree of KR anywhere and ive driven quite a bit.
Old Jul 9, 2009 | 03:00 PM
pHEnomIC's Avatar
bump please
Old Jul 10, 2009 | 07:43 PM
iowackers's Avatar
The best way I have found to check them is to monitor the knock voltage and use a hammer to LIGHTLY tap on the engine near the sensor. You should see a change in the voltage.
Scott
Old Jul 10, 2009 | 11:39 PM
pHEnomIC's Avatar
Scott
Great idea, thanks!
Old Jul 11, 2009 | 01:32 PM
my 1st LS1 SS's Avatar
Hey Iowackers where are you located? I am looking for a speed shop in central Ia. that can help me with my 98 SS.
Old Aug 19, 2009 | 06:02 PM
pHEnomIC's Avatar
I can't find a PID to monitor knock sensor voltage, any help on that or any other way to test these things?
Old Aug 21, 2009 | 10:14 PM
oange ss's Avatar
just monitor KR when doing the tap test, if the KS is reporting it will show up
Old Aug 30, 2009 | 09:06 AM
JimMueller's Avatar
If you still haven't gotten the results you were looking for, you can use a digital multimeter to monitor the output voltage of the sensors while lightly tapping on the block near the sensor.
Old Aug 30, 2009 | 11:01 PM
JDMC5's Avatar
you sure about that?
