Why is the ENG SEN fuse blowing?
What are my second choices for blowing the ENG SEN fuse?
Bad Blue WS6: was the offending wire found under the console? Was it a wire having to do with the tranny?
I still have not found the shorted out wire!!!!
I also removed the console since I had tranny error codes; I did not find any candidates here.
Also, I went under the car for the 4th or 5th time, and relocated the O2 wiring and the pass-side KR sensor wire. Since I have a LS2 402 stroker, the KR sensors had to be moved to the side of the block. But these wires have been thermally insulated and showed no wear.
I started the engine up last nite, after replacing the 20 amp ENG SEN fuse. I let the engine run for two minutes; it seemed to run very good. After shutdown, I checked the ENG SEN fuse, it was still good.
I should get 95/92 FAST system tomorrow. I will install this Saturday. When doing this, I will look for wiring issues behind the intake.
I went out for a 10 minute drive, running AutoTap (yes, I am a dynosaur). About 4 minutes into this drive, the MAF stop reporting a frequency. That is when I know the ENG SEN fuse has blown. Therefore, I have not located my short.
Does anyone have any help for me? I am at my wits end here!!!!!!!!
(or de-pinning at the PCM connector, if you have or can fake a
pin removal tool) the O2 sensor heater power feeds, high side.
Maybe start with rears, if fuse blows again kill the fronts, if
that doesn't stop it you're down to the on-motor sensors. This
ought to get it narrowed down, then you would have to find the
real flaw and fix it plus the cuts / pulled pins. But soldering on
the heater feed won't hurt anything other than cosmetics.
Have you tried simply pulling the sensors at their closest connector
to the PCM, one by one (I assume you have a pack o' fuses handy)?
. But yes like everyone else said it's something a ground touching or something. Anyways - 98z28 - no headers, nos, turbo, or any of that.
I have sat under my car to no avail - no burned wires, just the same 2 codes 0803 and 0102. The wire looms are in great condition - I figured if the O2 sensor failed it would run like crap like it did before. Plus it throws a separate code.
What is your opinion on installing a whole new harness?
