Tuning Question about IAT Sensor
a prime factor in air mass calcs. Unreasonably wide.
You may want to consider relocating it to a place
that sees no engine bay air, and maybe isn't black
(I just put mine up into the fresh air vent at the
cowl, but see it at 115F cold-motor, parked in sun).
Front bumper may be better though more wire.
If you use the timing trick then moving the sensor is irrelevant because it will just read a set value that won't change.
You can also get IAT extensions in 12", 24" and 36" lengths for around $30.
