Can you log speed vs RPM to detect clutch slipping?
Just curious can I log speed vs RPM and look for an RPM spike to indicate the clutch slipping? When on the street I think I am getting a little clutch slippage at high RPMs. The problem is that everything happens so quick that it is hard to tell between tire spin and clutch slipping, or even belt slipping. The car makes 750 rwhp through 3.73 gears. I know once I get to the track I will be able to tell more easily, but if I need a clutch I want to change it out now. Also there is no burnt clutch smell.
Thanks
Thanks
