98 to 99 pinout clutch pedal
There are 2 plugs on that cpp switch, you need to use the one that is CLOSED while the clutch is not depressed.
Then opens the circuit while you press the clutch.
It has to show a ground to the computer while you are off the clutch and it needs NO ground when you press the clutch down.
