Runs awesome one second...
Old Sep 17, 2009 | 11:49 AM
'02TA's Avatar
Angry Runs awesome one second...
So this problem is completely random and effectively pisses me off to no end on a daily basis. My car is an 02 T/A, cammed, full bolt ons, full exhaust, stalled and tuned.
Ill be driving the car and it'll be running fantastic, top-notch, like a top, amazing...and then out of nowhere it'll start missing very badly and the ses light will flash and the car has no accelerational power. The thing that is very odd to me is that if I floor the car during on of these episodes it runs awesome as long as my foot is planted. Flooring it also seems to cure the problem sometimes as well. And then just as quickly and randomly as is appeared the miss is gone and the car drives perfect again. Sometimes I can make my commute to wherever I'm going without an incident but like I said it happens at least once everyday I drive the car.
Old Sep 17, 2009 | 11:51 AM
blackhawk0251's Avatar
Does it snap back into timing when it does that? M6 or A4?
Pull your kick panel under your pedals and check the clutch cruise safety switch, this same thing happend on my firehawk and I ended up taping the button down so the switch remained open.
Old Sep 17, 2009 | 11:57 AM
'02TA's Avatar
It's A4. When it starts missing the car has to be at very low timing like maybe 3 or 4 degrees but when i punch it it goes back to full timing and hauls a$$
Old Sep 17, 2009 | 12:13 PM
Ah ok..A4..sup lol.
I would start by checking the cam position sensor and making sure its reading the correct voltages.
Old Sep 17, 2009 | 12:21 PM
'02TA's Avatar
I could see checking that but if it's missing and I floor it and it runs fine and then misses again for a little bit and the cam position sensor was bad wouldn't it not run great when @ WOT???
Old Sep 18, 2009 | 08:44 AM
'02TA's Avatar
C'mon guys I'm gonna work on it this weekend and I kinda wanna get a couple possible sources so i can check them all out...
Old Sep 18, 2009 | 10:04 AM
oddwraith's Avatar
Sounds like your wide open throttle settings are fine then. What about your timing? Need any retard there maybe? Is it only after the car warms up; never doing it on a cold start?
Old Sep 18, 2009 | 11:26 AM
'02TA's Avatar
Its always after the car warms up a bit, maybe not always at full running temp but when it would be in open loop I would assume. Also forgot to mention that these $hitacular episodes only everlast a couple minutes at most and thats without me trying to "fix" it by flogging the gas a couple times.
Old Sep 18, 2009 | 11:36 AM
jmill96Z's Avatar
Do you have tuning software? Any chance you can log?
Old Sep 18, 2009 | 01:24 PM
'02TA's Avatar
It's tuned with HPtuners but I'm not a tuner by any means, It was tuned by a very good local shop who is a sponser on here. I don't have any logs but I do plan on trying to take it down there to see if he can log it when this problem strikes...problem is that it never happens when im down there. Go figure...
Old Sep 18, 2009 | 04:48 PM
MRZ28's Avatar
Possibly a bad or loose MAP sensor.
Old Sep 20, 2009 | 10:17 PM
mrfrostberry's Avatar
have you checked all the grounds? i know i've had a ton of weird intermittent problems from loose grounds.
Old Sep 21, 2009 | 12:06 PM
'02TA's Avatar
The MAP sensor has been throwing a code for the longest but I've always just credited that to the cam...even tuned with, from what I'm told by the tuner, parameters that should never throw a code.
And yes my tuner also told me to check the grounds and I'm going through them now doing voltage drop tests. Does anyone know exactly which grounds I should be paying more attention to? Are any that are more prone to loosening or rusting?
Old Sep 21, 2009 | 01:01 PM
therealthatguy's Avatar
O2 sensors?
Old Sep 21, 2009 | 01:06 PM
'02TA's Avatar
My car isn't throwing any codes for O2's, if they were an issue then they would come up as a code right?
Old Sep 21, 2009 | 06:52 PM
Bad30th's Avatar
That's what I was gonna say... Are you SURE it's the tune and not mechanical in nature ?
Rob (Bad30th)
Old Sep 22, 2009 | 06:52 AM
rpmauto's Avatar
the tune itself cant change, once it is loaded it is there. It sounds to me like an electical issue. Either ground, or input-output from the pcm, bad wire ect.. Those are fun to find. Start moving the harness around while it is running and see if you notice any changes.
Old Sep 23, 2009 | 10:01 AM
'02TA's Avatar
That makes good sense...gettin to it right after work
