LC1 ground questions. did search and found conflicting answers
I am getting ready to install my LC1 in my car and have a question regarding the grounding. The LC1 manual says to solder the blue and white wires together and install them on the motor, i was going to use the back of the cylinder head, however when looking on here and on hpt forums alot of people are saying to move the grounds farther apart and only use the heater ground (blue) on the back of the head
which setup is best and if your running an LC1 how do you have yours wired and does it function correcting. this will not be setup in place of a narrowband 02
thanks
thanks
Not sure if it is the best but I tied my white and blue together and then ran that wire to the back of the passenger head. I think the thing you want to avoid is multiple connectors on a single lug. My setup is working well right now.
Charlie
Charlie
