Pulls all timing under boost
Old Dec 11, 2003 | 08:54 AM
Dumbkid's Avatar
Default Pulls all timing under boost
What am I missing here? It's an 02 C5 with a Vortech. As soon as the car sees boost, it just lays down. EFI live shows the timing goes all the way to Zero at times. No knock retard, just pulls all the timing.
It's not the 1514 code or anything. That's gone.
I had the exact same thing happen on an 01 last year. I just ended up having it tuned elsewhere and don't know what they did. I'm positive that there is a table that I'm just not aware of. Any help?
Thanks
Old Dec 11, 2003 | 05:58 PM
Slowhawk's Avatar
LS1Tech Sponsor
What's your complete setup and tune?
Old Dec 11, 2003 | 09:05 PM
Bink's Avatar
This may help you - new table in Edit v1.31.Here's a link for infoEdit info . FWIW.
joel
Old Dec 11, 2003 | 09:08 PM
Dumbkid's Avatar
It's a bone stock C5 auto.
All I did was copy the timing tables, and a couple of other things from a friends stick shift car. I know the tune is not going to be perfect but it shouldn't do this.
What is different about the automatics?
Old Dec 11, 2003 | 10:08 PM
Slowhawk's Avatar
LS1Tech Sponsor
If you can,send your Edit file to my E-mail so I can look at it.
Slowhawk@comcast.net
That might give me some ideas.
Old Dec 12, 2003 | 12:13 PM
red ws6 99's Avatar
If you did not delete torque management you will get all your timing pulled on shift.
Gary
Old Nov 19, 2007 | 12:39 PM
Alvin's Avatar
Old post but bump.. I've done quite a few of these things and now all of a sudden I got a car that seems to go between 0 and -4.5 degrees at around 5psi. Its a auto vette. commanded 18 degrees with 3 or so pulled out in the boost retard table (os 3 efilive)
What is the fix for this?
Old Nov 19, 2007 | 01:28 PM
SSpdDmon's Avatar
First place I'd look is burst knock retard. It will NOT show up under the regular knock retard pid in the scanner. You'll have to log GM.EST_KRB_DMA to see if that's the culprit. If so, then you'll need to adjust B6210 Burst Knock Delta Air Mass by increasing it 200~300%.
Then, I'd look at IAT's and what the B5911 Spark IAT Table might be pulling from the commanded timing.
Old Nov 19, 2007 | 01:38 PM
wait4me's Avatar
I second the burst knock thing. It is always the cause.
Old Nov 19, 2007 | 04:36 PM
Alvin's Avatar
I don't thik thats it cause the burst knock table is only around 5 degrees. we are talking about a -20 degree difference.
Old Nov 19, 2007 | 04:46 PM
Alvin's Avatar
Zeroed out burst knock and I have 0 degrees right at 120 kpa and -4.5 degrees right at 145kpa. Alsohave tried the stock OS and no luck!
Old Nov 24, 2007 | 09:41 PM
Alvin's Avatar
Found it!
DUH missed it.. under traction control theres a table "max torque per gear" Such a stuiped mistake.. Maybe it will help someone else.
