timing 40 degrees at WOT???
It is very powerful. As far as ease to use, that is your call. I would download both HP tuners and EFI Live and see which one you think you would be more comfortable using.
Again, i prefer EFI Live, as it is easier to use from a develpment standpoint.
The cost is $799, and that give you the ability to tune 2 vehicles.
Let me know if this is a route you want to take.
Thanks,
Spark and fuel are both based on the airflow into the engine, and I'd really be amazed if your spark lookup table referenced 40 degrees of spark at the amount of airflow an LS1 should see at full throttle.
Try putting your stock MAF sensor back on and watching the scan tool again. If you don't have it, try unplugging it and seeing what the scan tool does (airflow will be calculated in speed density mode, and the car will be running on the low octane table now too...which should definitely show you less spark advance...so if it still shows you 40...it sounds like you're having some compatibility issues with the scanning software and the PCM.
Thanks,
What year/model/vehicle do you have...?
2001/2002 F-car: COS5 will fit straight in.
1999/2000: tables have to be copied.
1998: require 411 PCM swap, PCM connector re-pin, fuel segment swap (it's not that hard).
You can play with the actual software, download/install from here.
It comes with sample log/tune files from real vehicles, you can view/edit those.
