Master efi tuner - gm efi...pre-order now
Old Dec 28, 2009 | 09:50 AM
dan@masportspeedshop's Avatar
LS1TECH Sponsor
Originally Posted by eliotmansfield
Hi,
Does the book cover the E38 controller?
YES, the first case study is of a 2007 Corvette with some simple bolt-ons. The book does't go into detail about the specifics of one controller vs another, rather it shows you how to tune using a tuning process that's effective and efficient. The same tuning process I lay out in the book can be used to tune any engine that has EFI, regardless of controller type, but yes, you will see how an E38 ECM can be tuned using the '07 Corvette as an example.
Old Dec 28, 2009 | 09:54 AM
LS1TECH Sponsor
Originally Posted by adkunlimited
i just ordered the package with hp tuners pro with the book. is that the new book or the old one that will be coming with it?
yep, just as poconojoe says...new books only from here on out. It's similar to the old book, but it's strictly GM info...no Ford or other stuff. That's coming in a separate new book soon.
Old Dec 28, 2009 | 10:00 AM
LS1TECH Sponsor
Originally Posted by shoemike
Too bad this is only for hptuners,
an EFILive version would probably be a good seller.
We are putting together an EFI Live version that should be out in the coming months. This project, and Ford EFI will be coming around spring of 2010. Not long after we'll have a Chrysler HEMI tuning book out as well. "No (WILD)child left behind"...
Old Dec 28, 2009 | 10:47 AM
adkunlimited's Avatar
ok thats great news. i cant wait to get it. thanks for the quick repley.
Old Dec 29, 2009 | 07:34 PM
sheikss's Avatar
Does this cover speed density tuning and how to configure things for it? If so I'll be ordering by thursday at the latest.
Old Dec 30, 2009 | 01:57 PM
LS1TECH Sponsor
It sure does! Airflow modeling (both MAF and VE) is covered in the theory section of the book, and Case Study #3 covers Speed-Density (aka VE) tuning using a turbocharged '02 Camaro with a 2-bar speed-density tune as the real-world example. I'm quite sure you'll find Case Study #3 more than useful when learning how to tune speed-density systems.
Cheers!
Old Dec 31, 2009 | 12:11 PM
sheikss's Avatar
about to call
Old Dec 31, 2009 | 12:17 PM
sheikss's Avatar
Ordered, I suppose that comes with a free shirt, right? Just kidding can't wait to get the book.
Old Dec 31, 2009 | 09:41 PM
SlickVert's Avatar
Sound great, I will order the books soon. Is there a place that I can get HPT and the book at one place?
Bob
Old Jan 1, 2010 | 05:43 AM
poconojoe's Avatar
Bob
Dan will sell it to you as a package deal
Old Jan 1, 2010 | 06:36 AM
SlickVert's Avatar
Great, I will give them a call.
Quick question, my motor make peak power at 8,000rpm. will HPT be able to tune up to and beyond 8,000?
Also, how high of a rpm will I be able to adjust the rev limiter.
Thanks
Old Jan 1, 2010 | 09:13 AM
  #32
foff667's Avatar
LS1TECH Sponsor
Thanks
8000 is right around the end of most tables(they are hardcoded by GM)
for instance the spark tables(high & low) go to 8000 rpms then the last cell is used thereafter.
Rev limiter hardcoded limit goes to 12800rpm.
Old Jan 7, 2010 | 02:52 AM
  #33
eliotmansfield's Avatar
I asked about the E38 because it doesn't have a traditional VE table as such.
Old Jan 7, 2010 | 08:33 AM
  #34
LS1TECH Sponsor
True. The E38 is capable of floating-point math and so calculates VE in real-time using polynomial constants (in the virtual VE table), but again, the tuning process laid out in Case Study #3, the turbocharged Camaro which uses a traditional VE table, still applies to the new style "virtual VE" table.
Case Study #1, the '07 Corvette DOES NOT have VE tuning due to the relatively stock configuration of that specific car, but Case Study #3 is all about VE tuning. Different application, but same tuning process.
Old Jan 8, 2010 | 01:56 AM
  #35
BLK,97,T/A,M-6's Avatar
I am an LT1 guy, will this book pertain to my vehicle? I will need to tune a 95 camaro, and a 97 T/A, will your tuners pro kit do the job for both cars?
Old Jan 8, 2010 | 07:31 PM
  #36
DiabloFormula's Avatar
Wow!!!!!
Just got done reading this book, the case studies really open up what the rest of the book is telling you, props to you Dan!!!!!! Great Job.
Old Jan 9, 2010 | 06:57 AM
  #37
LS1TECH Sponsor
The book outlines a tuning process that can be used to tune any EFI engine, but it focuses on late-model LS engines. As for the tuning software, sorry but no, it does NOT support LT1 tuning at this time.
Old Jan 9, 2010 | 07:01 AM
  #38
LS1TECH Sponsor
Originally Posted by DiabloFormula
Wow!!!!!
Thanks, man! I'm really glad you liked it and I truly appreciate the kind words and support!!
Old Jan 9, 2010 | 10:19 AM
  #39
tsench's Avatar
this is tempting i got hp tuner and Bob tunning book and it expensive compare to this one im thinking switch to EFI are hp and EFI similar and what option hp have and EFI dont
Old Jan 9, 2010 | 10:36 AM
  #40
69LT1Bird's Avatar
They are both good tuning tools. The books, classes, videos, and forum community for user support, is a lot bigger for HP Tuners than EFI LIVE.
