pcm can read tune but can't flash, failed bootloader
Old 01-06-2010, 10:06 PM
pdasterly's Avatar
Default pcm can read tune but can't flash, failed bootloader
pcm wont accept flash, pcm is good and was reflashed on a bench harness. Im having some sort of electrical issue and dont know where to start?
Old 01-10-2010, 02:09 AM
pdasterly's Avatar
anyone?
Old 01-10-2010, 06:49 AM
MUSTANGBRKR02's Avatar
What are the error codes you are getting?
Old 01-10-2010, 10:38 AM
eseibel67's Avatar
If your PCM accepted a bench flash, but not an onboard, you may have a problem with your DLC connector.
Old 01-11-2010, 03:28 PM
wait4me's Avatar
Can the tune be flashed on the bench harness? Or just read.
It is impossible... yes impossible for the read to work and the write to fail due to a seed/key missmatch.. The key for reading is the same for writing, so it cant be locked..
The only thing to check is you have the correct ecm type selected depending on your software you are using, OR check for 12v and grounds at your connector under the dash that you are plugging into to see if it has power and is working.
Old 01-20-2010, 11:44 AM
pdasterly's Avatar
fixed the problem, I just drove around some more and everything works fine now. I guess i had a gremlin in my system, the car was put together from three differant cars
Old 01-24-2010, 03:00 AM
joecar's Avatar
Gremlins = electrical problems (power/ground connections may have corrosion/resistance)...
But I am happy you got it going......is this the 99 or the 98...?
Old 02-07-2010, 11:03 PM
pdasterly's Avatar
Firebird 99
Old 02-08-2010, 11:11 AM
edcmat-l1's Avatar
Voltage was probably too low. I've seen that set a boot load error.
Quick Reply: pcm can read tune but can't flash, failed bootloader
