Timing under WOT ??? help!
Fix your knock sensor(s) and/or pigtail(s).
On a recent post for vehicles that have the LS6 intake, they do not like more than 25 degrees of spark advance at WOT. Since yours is a 2001 (no LS6 intake?) try ~27-28 degrees at WOT (on a dyno).
Hey, that is just a guess on my part. A dyno will reveal the truth. You may have to alter the WOT AFR slightly for street, but once you get the KR sensors fixed, it will be easier to do WOT tuning and determine your ideal spark and AFR.
I had a high compression motor that would only take 24 max.
Now I have an LS3 that likes 29. Every motor is slightly different, depending on a lot of factors, including the outside air temperature, and what the real octane number is on the gas in your tank. I keep adding timing and scanning until I see some knock, then back off a degree or two. Double check it on a hot day, it may knock then.
It is possible that one or two cylinders (say 7 and 8) are more prone to detonation under given conditions than the rest, and in the case that the other six are still timing hungry you can still see an over all increase in power dispute the two cylinders being on the verge of detonation. for this reason i like to back off a touch after peak power is found.
got a link to this thread?
