Maximum power @WOT
But what compression are you running?
do you have TX giant too?
then what heads?
my timing at WOT is 31-32 from TSP
thanks
Baezi
You can't be doing that with 92 pump gas can you. ?
Do you buy 100 octane race fuel by the drum. How much do you pay per gallon.
I had a 11.5 LS6 motor and had to run at least 50% of 100 to keep it from knocking at 25degrees. Now I have a LS3 bottom end with flat tops. I love pulling into a gas station and saying fill it up with your finest 92. It never knocks with 29 degrees at WOT.
i´m running 31-32 timing , have never seen knock..
running Shell V-power, i think it´s around the same as yours premium 95 oct
i hope my knock sensor is working though
Baezi
Baezi
you do realise no two engines are the same. 28-29 may be good for you while it maybe to little or too much for some one else that is the reason we dyno tune each car and not run one tune for everyone
Every combo is different, shape of the piston crown and cylinder head chamber play a roll in this, as well as bore size, fuel type, engine temp, oil temp, spark plug type, cam specs, etc. I would not trust the knock sensors 100%, you have to try and look at several different things to get a good idea as to how much timing you should run. Just because you do not see any signs of knock with 40 degrees of timing on a particular combo does not mean that’s were you need your timing at, it might make more power at 30 degrees.
I know lots of us like to think that the reason we do not need much more then 29 degrees of timing is because of the efficiency of our cylinder heads, but I think it has more to do with the pump fuel quality, the higher compression ratios our LS engines come from the factory with (as compared to old school factory stuff), the low octane fuel we buy at the pump, and the higher engine temps these engines run stock then it does with the cylinder head design. If you cool the engine temps down, run better fuel, and a list of other things you can see a large increase in power from bringing the timing even farther up, but who can pull up to a pump and buy 108 octane fuel for less then 7 bucks a gallon every were they go?
I guess what I am getting at is there is no "x" timing that is perfect, every combo is different and every drives environment is different, thank God for Hp Tuner and EFi Live so we can set up our cars for our situation.
the AFR change wont effect anything at all. as long as you are within a safe boundry and to find that boundry you will need a dyno. dyno is not for bragging it is to see the change in power output.
