Launch Control/2-Step for LS1...
Old Mar 21, 2010 | 08:55 PM
Matt_2000_SS's Avatar
Default Launch Control/2-Step for LS1...
Been diggin around and can't seem to find a solid answer... Is there anything out there, ie. 2-Step, that will work on a 2000 LS1, M6 car?
Also, I have heard with other cars, they can use the tuning software, HP Tuners, to make a rev limiter to be used for the same purpose.
Any help would be much appreciated.
Thanks, Matt.
Old Mar 22, 2010 | 01:16 AM
Wnts2Go10O's Avatar
LPE and MSD. Harlan used to make em
Old Mar 23, 2010 | 07:11 PM
Thanks for the info. Now, does anyone have any experiance with either brand? Also, how complex is the install?
Old Mar 23, 2010 | 07:31 PM
Zmg00camaross's Avatar
I have the msd launch controller, one wire hook up for signal, the others piggy back into the coils. it serious took 25 minutes, i have it hooked to the clutch switch, mounted on passenger side there is a access hole under the pcm, ran the wire inside over to the clutch pedal. This doesnt control timing or anything just controls rpm when activated. bought mine from speed inc one of are sponsers over there >>>>. hope this helps a little
Old Mar 23, 2010 | 09:22 PM
DiabloFormula's Avatar
MSD 2step here, cake walk to hook up and it works great.
Old Mar 25, 2010 | 02:55 AM
LSxPwrDZ's Avatar
Will be going with the Lingenfelter unit myself to retard the timing when I spray so I don't have to flash the car to pull timing. I had the older Lingenfelter unit that was only a 2step and it was very easy to hook up! Plug N Play and a 12v or ground activation wire.
Old Mar 26, 2010 | 12:04 PM
digitalsolo's Avatar
I have the Lingenfelter unit.
Works great, SUPER easy install. Hook two leads together for your main rev limiter, and hook the other one to get +12 when you want the two step active (mine is on a clutch switch). The unit just plugs inline with the coils and BAM, you're rolling.
I will say, it scared the hell out of me the first time I staged it and it started popping in the exhaust while spooling my turbo. BANG!
Old Mar 27, 2010 | 12:22 PM
06X6spdGTO's Avatar
lingenfelter LNC-002 here. It works great. now i would like to go a little bit farther on my 2 step install to put a limit switch to activate the unit when the car is in 1st gear only!! doing this to avoid the popping between shifts from the rev limiter activating everytime the clutch is pushed in. I could try and post a video of it working on my C5Z.
Old Mar 27, 2010 | 05:23 PM
Mike@ZMS's Avatar
I have 2 of the MSD 8733 LSx 2-Steps in stock right now.
$190.99 with coupon code "8733tech"
http://www.zenithmotorsports.com/msd...p-for-lsx.aspx
Old Mar 27, 2010 | 09:32 PM
Here's a sound clip of the MSD 2-step on my car....
http://www.youtube.com/watch?v=66FMd8M6Lpw
Old Mar 28, 2010 | 05:02 PM
98mysticZ's Avatar
what wire are yall tapping into to get the 2 step to work?
Old Mar 28, 2010 | 05:26 PM
06X6spdGTO's Avatar
clutch safety depress trigger. The one you have to engage to start the car.
Old Mar 28, 2010 | 06:17 PM
Nsty98LS1's Avatar
this is probably a dumb question, but the MSD cuts spark correct? if so, i'm ordering one tonight.
Old Mar 28, 2010 | 07:30 PM
^^^ Yes cuts spark, dumps fuel blows flames. Is that why you want one?http://www.youtube.com/watch?v=xpXblRXxCCY
Old Mar 29, 2010 | 03:28 PM
Nsty98LS1's Avatar
yeah, thats the only reason i want one. i don't like the idea of cutting fuel if i decide to go back to spray.
Old Mar 29, 2010 | 05:37 PM
MUSTANGBRKR02's Avatar
Just ordered one thanks.
What is the surcharge for?
Old Mar 29, 2010 | 09:53 PM
98mysticZ's Avatar
ok so i am looking at this but it only has a trigger when u start the car.. mine has now power or ground so i am just alittle confused.. did u use the power or ground to trigger it?
Old Mar 29, 2010 | 10:26 PM
06X6spdGTO's Avatar
i cut the current wires on both sides and branched off the power. So now my 2step only has "Active" power when the clutch is depressed. I then took the two stock wires, (bottom and top of the trigger) and sodered them together.
The only thing is if you go this route your car will start without pushing the clutch in.
Check the Corvette forum for a picture install. A few ppl have even gone far enough to put a 1st gear limit switch in. This way the unit is only active while in first gear.
Old Mar 29, 2010 | 11:19 PM
i just splice into one wire and works when its depressed. And the switch works like it suppose to cant start it untill you push the clutch down.
Old Mar 29, 2010 | 11:28 PM
98mysticZ's Avatar
but here is the whole deal on that .... the lower switch (black) only gets power at "start up" and other then that has NO ground or power.... which is why i was confussed
