HPTuner Scale for Red Top Ford Injector
Old Mar 28, 2010 | 10:30 AM
BLUEBYU's Avatar
Default HPTuner Scale for Red Top Ford Injector
I have researched the repository and cannot find a file with these injectors. The stock tunes indicate a difference of 2.55 from 0 to 80 kPa. I understand that these injectors are rated at 36# @ 58 psi. So, would my scale be 36 to 38.55? I thought i had a previous tuner take care of this, but my current scale is from 37.33 to 40.92. Thanks for any help here.
Old Mar 29, 2010 | 09:45 AM
BLUEBYU's Avatar
Anybody? Or direct me to where I can get this information.
Thanks.
Old Mar 29, 2010 | 10:24 AM
MUSTANGBRKR02's Avatar
I pm'd you and asked for your email, but I guess you don't want it.
Old Mar 29, 2010 | 10:50 AM
BLUEBYU's Avatar
My PM has never worked and has been very frustrating to say the least. Can you email me at randyhughes@reeceandnichols.com. Sorry for the hassle.
Old Mar 29, 2010 | 02:52 PM
I will email it to you when i get my desktop fired up in a few.
Old Mar 29, 2010 | 08:03 PM
BLUEBYU's Avatar
Thanks man. I sure appreciate the help. This tuning crap is driving me frickin' crazy. Big distraction, but I know I will figure it out......eventually.
Old Mar 29, 2010 | 08:18 PM
Just sent it.
Old Mar 31, 2010 | 11:08 AM
BLUEBYU's Avatar
Great information!!! Everything you need to know about injector parameters and more.
Thank you very much!
Old Mar 31, 2010 | 09:26 PM
Rocko350's Avatar
Mustang, possibly could you email it to me as well. I have a 98 with red tops i have to get straight. rocko350@yahoo.com. Thanks if you can, if not can you point me to where i might find it?
Chris
Old Apr 1, 2010 | 03:39 PM
BLUEBYU's Avatar
This information does not line up with 3 repository files that have the same scaling. Why is there a difference? Did notice the information you sent is for 3 Bar.
Old Apr 1, 2010 | 03:56 PM
camscam02's Avatar
mines 37.51-41.11
Old Apr 1, 2010 | 04:15 PM
JonCR96Z's Avatar
Every injector is different, every regulator is different, every fuel pump is different, etc,...
You could have the exact perfect data for an injector tested on a bench some where but yours are gonna be different. Haggling over less than a 1lbs/hr is a waste of time. However having a pretty close estimate on all the injector data (not just IFR) will go a long way in making your tune that much better.
Old Apr 1, 2010 | 04:34 PM
BLUEBYU's Avatar
Originally Posted by camscam02
mines 37.51-41.11
That's pretty close to my original scale done about 4 years ago. Did you mess with the other scales and values....offset, minimum, default values?
Old Apr 1, 2010 | 04:55 PM
camscam02's Avatar
No clue, this is what my tuner did, I trust him 100% and have no need to question him. I have the software to tune the nitrous side of things and make small changes when needed.
I still have a lot of learning to do.
Old Apr 2, 2010 | 12:30 AM
racecar's Avatar
There are a lot of opinions about how the SVO 30 lb are rated, 3 bar (43.5) or at 40 psi.
My numbers are 36-39. You have to decide what numbers you want to go with, stick with them. and start tuning your VE.
By Brett Foote | 2026-06-04 05:00:17
