Deleting O2's with Predator
I have done a search and havent found any good answers.
Im now running an ORY. I want to "turn-off" the associated O2's. The Predator gives me the option to turn off various sensors. Which O2 sensors do I need to "turn off"
I am given specific numbers.. I can hook it back up and post the numbers here if necessary
LS1Tech Sponsor
disable codes P0420, P0430, and anything else relating to the rear O2 sensors in the predator... i.e. anything that's O2 bank 1 sensor 2, and O2 bank 2 sensor 2
__________________
06MonteSS / DiabLew Tune
![](https://ls1tech.com/forums/signaturepics/sigpic53380_2.gif)
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
LS1Tech Sponsor
well, if you have a newer predator on a 9rxx revision (I dunno, you didn't say), then you will not have any of those options... because that functionality was removed due to EPA regulations...
you'll need to get a custom tune made by a diablosport CMR tuner in order to get the codes disabled in a custom tune file.
__________________
LS1Tech Sponsor
because any emissions-related-defeating products are "illegal" for vehicles driven on public roadways... there are very very very stiff penalties involved if caught doing it...
so, the functionality was removed from the handheld units so that end-users can not do this themselves on every-day vehicles that are driven on public roadways...
and you are still able to do it in a custom tune via the tuning software, because in the disclaimer - just like in the handhelds disclaimer, it states that tunes are for "off-road use only"...
"DISCLAIMER Not legal for sale or use on any pollution controlled motor vehicles. Legal in California only for racing vehicles which may never be used upon a highway."
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
__________________
These are my options to turn on/off under
"OBD-II 02 sensor"
P-0137
P-0138 & 140
P-0141
P-0157
P-0158 & 160
P-0161
P-1133.1134.1153.1154
Not sure which software I have. How do I find out?
Thanks
Nate
"OBD-II 02 sensor"
P-0137
P-0138 & 140
P-0141
P-0157
P-0158 & 160
P-0161
Thanks
Nate
While I have you here.. I found this on Predators site a while back and cant seem to find it again.
Any idea what the part numbers are at Radio Shack for the cable I need to hook this up to my laptop?
LS1Tech Sponsor
if those are all under the 02 Sensor section, then disable them all...
__________________
LS1Tech Sponsor
1: Serial Cable:
Standard straight-through DB9 (9-pin to 9-pin) RS232C serial cable (6 foot cable is more than enough). Check your computer to see if you have a male or a female port on the back, as some are different. You will need a male end to go into your Predator.
(Radio Shack Part # 26-117, 6-ft DB9 male to DB9 female shielded cable.)
If you do not have a serial port on your PC you can use a USB to serial adapter. Be sure to install the driver that comes with the cable so your PC can recognize the cable.
2: Power Adapter:
CLASS 2 TRANSFORMER
OUTPUT : 12VDC 1000mA (1 Amp)(Radio Shack Part # 273-1776)
Note: Plug Tip is 2.5mm x 5.5mm, female, and center is positive.(Radio Shack Part # 273-1717)
Radio Shack normally carries both of these items. Most Wal-Marts have the Power Adapter (multi output version).
__________________
