LQ4 to LQ9 pistons
Old Mar 30, 2010 | 08:41 AM
Triaxle's Avatar
Default LQ4 to LQ9 pistons
I have a rebuilt LQ4 switched to LQ9 pistons and cam. I'm a noob with fuel injection systems and how they work. Is the LQ4 calibration going to be ok with the changes until I get a new tune? Or am I better off getting an LQ9 computer to start out with?
Old Mar 30, 2010 | 09:27 AM
oange ss's Avatar
fuel and spark requirements will change with the increase in compression and cam change, you need a real tune for the new setup
Old Mar 30, 2010 | 10:47 AM
Old Geezer's Avatar
Aren't LQ4 and LQ9 cams are the same specs...
Old Mar 30, 2010 | 10:51 AM
69LT1Bird's Avatar
The only difference is the compression ratio, a .5 bump up for the flat tops. Don't sweat it, you will be fine with the LQ4 PCM and calibration.
Old Mar 30, 2010 | 10:55 AM
Triaxle's Avatar
Sorry wasn't specific there, I actually have an aftermarket cam.
Alright the compression bump was what I really wasn't sure about. Thats makes things a lot simpler.
Old Mar 30, 2010 | 10:58 AM
69LT1Bird's Avatar
Well that changes things. The compression ratio won't be the issue but the cam swap could be.
It should start and run, how good, hard too tell. I would take it easy until it gets tuned.
Old Mar 30, 2010 | 11:03 AM
Triaxle's Avatar
Alright thats my plan. I have a 228R right now a friend gave me, but I think I want to have a custom cam made. Thanks for the input
Old Mar 30, 2010 | 12:33 PM
69LT1Bird's Avatar
You did check PTV, right?
Old Mar 30, 2010 | 01:59 PM
Triaxle's Avatar
Haven't put heads on the block yet, but don't think I'll have any problems there. Still have a lot of chassis work to do.
Old Apr 1, 2010 | 09:02 AM
Old Geezer's Avatar
Exclamation X2..
As bird said....
