HP Tuners Cylinder Balance Q
The way to interpret the results is the cylinder with the highest RPM is the weakest. ie turning it off has had the smallest effect on the idle speed. The tests can tell you which cylinders are low on compression, have a weaker injector, or even if a plug is breaking down.
