Pros and cons of SD Tune?
Old Apr 6, 2010 | 09:46 PM
bayer-z28's Avatar
Default Pros and cons of SD Tune?
From what I gather the MAF is used mainly for drivability and lower RPM's and the SD Tune is a PITA to tune.. May the MAF be why the LS1 setup drives better?
Ideas? Pros+Cons?
Old Apr 7, 2010 | 07:52 PM
Ramairbird's Avatar
Do a search on this, you will find tons of opions about it. I'm going SD, I was very hesitant but my buddies car just got tuned in SD and it runs great. It is all in the tune. It takes alot to get the VE right but it can work well. It also depends on your set up, why do you consider going SD? Are you flowing so much air that the MAF is a restriction? Either way can be tuned well by a good tuner, it just depends on what your needs and goals are for the car.
Old Apr 9, 2010 | 08:22 AM
bayer-z28's Avatar
Well, I'm lookin into getting a massaged 92/92 setup, with possibly a larger TB, I'd like some different as well. I'd like some TFS heads, but I'm not sure I'll ever be ready to drop that coin..
I was thinking SD to get the MAF out of there. It'll have to be done eventually.
Old Apr 9, 2010 | 09:47 AM
Dskeet6's Avatar
sd closed loop is the way to go.....
Old Apr 9, 2010 | 10:51 AM
Slowhawk's Avatar
LS1Tech Sponsor
There is no power gain going to SD. I go SD on some cars for a few reasons. Huge Cam with alot of overlap or FI to control different boost level settings.
Thats about it.
Old Apr 9, 2010 | 10:53 AM
69LT1Bird's Avatar
I am running a 100mm MAF closed loop and have no issues.
Old Apr 9, 2010 | 11:36 AM
edcmat-l1's Avatar
Thats about it.
I agree completely. I have plenty of cars out there with pretty big cams and still running a MAF.
Old Apr 9, 2010 | 06:48 PM
bayer-z28's Avatar
Ahh... I'm learning.. I know there's no power gain, just wondering about the other aspects of the setup.
Where the hell do you get MAF's that big??! What about a 92mm-ish MAF for a GMPP 90mm intake?
Old Apr 9, 2010 | 06:56 PM
lemons12's Avatar
IIRC ws6store has some pretty good sized ones, I think you can get a 100 from them, I know they have a 102mm lid.
Old Apr 9, 2010 | 07:06 PM
GMCtrk's Avatar
The main reason I like Speed Density is simply because there's less to tune. You only need to calibrate the VE table. If you run the MAF you also need to calibrate that as well.
Old Apr 9, 2010 | 08:10 PM
5.7 ute's Avatar
Ideas? Pros+Cons?
Maf is only used on its own after 4000rpm. Under this rpm its job is mainly to sanity check the dynair prediction.(SD)
Old Apr 11, 2010 | 10:40 PM
fastsspr's Avatar
Were you find that 100mm MAF?
Old Apr 11, 2010 | 10:59 PM
fastsspr's Avatar
sorry didn't that lemons12 says that the MAF can be finded in WS6 store!!!Sorry
Old Apr 11, 2010 | 11:05 PM
lemons12's Avatar
I'm not 100% on it.. Was browsing the other day and thought that is where I came across it.
Old Apr 12, 2010 | 05:33 AM
69LT1Bird's Avatar
You can use a GM Hitachi MAF from the LS3 Corvette which is also used in the Malibu I believe.
GM Performance parts sells a small aluminum adapter that you can attach to virtually any tube you want and the card slides into it.
It is part of the LS3 stand alone harness kit.
That or just get this http://www.powrmax.com/PowrMAF%20100.html
