Bad Problem!
Old May 12, 2010 | 02:26 AM
19BLACKBIRD99's Avatar
Default Bad Problem!
SO! I crank my car, and its **** bricks or something very choppy idle and it almost dies after I give it a rev, ive tried resetting my PCM and it still does it, but the weird thing is this problem only happens every so often, and I have noticed a lose of power around the 2k rpm range. any suggestions?
ps. ive checked all the plugs, wires, injectors. Im outta things to check lol
Old May 12, 2010 | 04:52 AM
Slowhawk's Avatar
LS1Tech Sponsor
Unplug the MAF and see if it helps.
Old May 12, 2010 | 07:06 AM
Old Geezer's Avatar
yep.. It's a real bitch when U get a brick stuck in the header pipe..
Maybe datalog it, and see what comes up??
Old May 13, 2010 | 12:17 AM
What would unplugging the MAF do?
Old May 13, 2010 | 01:09 AM
BobDoLe's Avatar
it would force it into speed density mode and if it stops giving you problems... it could be your maf going out.
Old May 13, 2010 | 01:15 AM
00MaroonZ28's Avatar
agreed. I've heard of this happening before and doing the same thing.
What exactly does speed density mode do? Sorry for the questions lol ohh and I tried it and it still bogged down and acts like it wants to quit, but when I plugged it up it fixed, the maf is basically brand new.
Old May 13, 2010 | 01:17 AM
Speed density just reads off the programmed Ve tables. Doesn't use the maf to correct for air differences. IMO it wakes a car up a lot if you do just a speed density tune. I'm doing that this summer.
