testing coil packs with a DVOM
Don't know what normal ohms reading would be from
IGN to driven to plug terminals. But the way you'd get
a spark fault is more likely an insulation breach, which
you won't be able to see at low meter-applied voltages
most likely.
Scanning for current misfires to find the misbehaving
cylinders, and then diagnostic component-swapping,
is the way to go. Maybe borrow somwbody local's
AutoTAP, HPTuners, EFILive gear - no licenses are
needed to scan.
