p430 and p420 and check engine light on
My 2000 SS has been running good till recently i got the check engine light and p420 and p430 dtc codes
P420 "Catalyst System Efficiency Below Threshold (Bank 1)" and P430 "Catalyst System Efficiency Below Threshold (Bank 2)"
i just put on brand new magnaflow catalytic converters
4 new o2 sensors
been running good till recently i got the check engine light and p420 and p430 dtc codes showing
it was coming and going
then after i changed oil and i put zmax in the oil and lucas fuel treatment in and then the check engine light came on steady....
im hoping my new cats arent bad already
a few members said it could be a body ground problem?.... which i will check this weekend
any other thoughts would be appreciated
thanks
also, just been noticing my radio led's flicker a little...which would support the body grounds theory as a possible cause that someone else posted
i disconnected battery terminals to look for corrosion, they had none
the body grounds i could see from the top of the engine all looked good ...i will be jacking it up probably this weekend to look for any underneath
do you mean, im guessing exhaust leaks before the catalytic converters
i will check that also this weekend hopefully
thanks
i replace the o2's with ac-delco
put a new timing chain in ....had the bat diconnected for a while
after the timing chain, because the batt was disc of course teh light stayed off for 2 days....car ran stronger and smoother.....real nice
and then.... the light cam back on again.....seems to always come back on just after i got on and off the throttle a few times....
the worst is and good news is i know it will run good if i find the problem.... so shouldnt be any internal stuff like a piston or whatever
thanks for the help so far
