Wideband single senor... best placement??
I've got a Innovate LC-1 kit and was trying to figure where would be the best location to install my wideband sensor. My off road Y has an extra bung on each bank after my primary O2's. I've seen several posts of guys saying the driver side is the leaner bank and to run a single sensor setup on the driver bank. Or is it more benifitial to weld in the bung that came with the kit just after the merge in my Y and install the sensor there? Thanks for any input.
My tentative plan right now is to wire the Lc-1 and use it as my narrow band (drivers side) and as a wide band guage in the car. I am mainly doing this because i dont want to weld in another bung, but if you already have extra bungs, i would say just use one of those.
