What besides TPS voltage would make a tranny short-shift?
I finally got back to the track this year after a few years off, and no matter what I did in the WOT shift MPH/RPM tables, the car would shift early on the 1-2, way early on the 2-3, and early on the 3-4 (while locking the TCC at the shift).
The car has a vendor built 4L65E, and a TCI 3800 stall converter.
I commanded the shifts at 6600 rpms, but the car was shifting at 5000.
No matter where I set the shift MPH, it would still shift at 5000 rpms.
Every thing I found searching was mentioning the TPS voltage triggering a "limp-home" mode. So I checked. 4.28-4.33V at 100% throttle.
Is there anything else in the PCM that could override shift tables and not throw a code? This has been haunting this car since 2006, and I'm fed up with it. I wanna race!
I'm going to start building a 4L80E for the car, and use a TCI trans controller when I finish. I wonder if I should wire the controller to my current trans and see if it's a PCM issue, or if the tranny could be it.
Before I go through all that trouble though, does anyone have any ideas as to what could be causing it? Anything would be helpful at this point
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
On the runs I logged before my PCM fried, I was getting 92-96% for the duration of the 1/4 mile. I don't think I ever see a true 100%. I haven't logged anything new since I got the new PCM installed last wendsday.
I'll try to make a run and log the TPS voltage.
Why do they have to make it such a pain lol
I'm within range of the lower and upper fault thresholds, and reading >90% TPS...
What would be the fix for this if it's not reading high enough? Without overshooting the 4.75V rule anyway.
