Opinion after tuning with HPP3
Changed rev limiter to 6300
Changed shift points to +3,+5,+5.
Changed Shift Firmness to 100%
Changed for the fans to come on early.
Pretty much everything else is left to stock, except for a few mods I have listed in my sig.
Should I leave this tuned to what I have listed? I did a search on the things to change and came up with what I have. Should I keep what I have? And it shoudn't damage anything.
Thanks.
(Don't have an drastic changes to warrant a LS1 edit tune yet, the reason for HPP3.)
Tony
How do you set the optimal shift points? I do have a GTECH PRO so i could say datalog the g-forces on a private street launch and see where the RPM * G forces are, in theory , if you get max G on each shift is that good? or how do you recommend. i'm a newb at this stuff (mostly all 5 speed cars before) so Automatics are quite a new realm.
if you dont mind explaining or pointing to a thread for a newb i'd appreciate it.
I'm still learing as well.
I picked a mild cam and gained 1000rpm of usable (5500 peak before, 6500 now) and the dyno run to 7200 just flatlined past 6600 so it made sense to limit it to 6600 and shift at 6400.
You can datalog G-force with efilive 6.2 i found out, i might have to have the tuner tweak shift mph and record the g-forces as you could deduce optimal shift points based on that. but i have a verter that limits my shift extensions a little.
Mine is set at either 25% or 50% dont remember. I wouldnt drive too much or too hard at 100% for too long. Also i thought mostly stock cars peak at about 5400rpm's. So with that i would try and play around with gettin to shift at no more than 5800rpms with a rev limit of like 6200, which i belive is stock. I could be talkin out of my ***, so somebody correct me if im wrong. The Best V8 Stories One Small Block at Time
