Ls2 90mm throttle body questions
I have a 6.0L engine and harness that I am building for a 1967 nova..
It will be turbo charged but have a few questions..
1.) Will the LS2 throttle body work with the stock wiring harness?
2.) If I stay with the fly by wire TB, can I use BS3, Fast or AMS EMS?
3.) Or should I go with a throttle cable Throttle body, I can get a Ls2 / ls3 throttle body for a decent price.
thanks
thanks
What year is the wiring harness? You may need a TB adaptor harness depending on what year wiring harness.
I don't think BS3 or any other aftermarket computer system is needed unless your goin to be doing some for crazy solid roller motor, or huge FI motor.
LS1Tech Premium Sponsor
What year is the "stock wiring harness" off of?
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I have a 2004 LQ4 with harness & engine from Chevy Truck.. no ECU currently.
but I am looking to buy a throttle body..
so what to do?
I am thinking of replacing the truck intake with an Edelbrock pro-flo XT 7139 or 7140 intake.. depends if I get the LS1 or LS2 style throttle body
so what to do?
