Timing dropping out intermittently under WOT? Ideas?
Pretty sure all the burst knock is eliminated, only noticed it under WOT and its when launched, it dips sharply pulling 8-10 degrees out spiking to normal, down, normal, down and eventually stops going down track.
Thats listed at 10 degrees, no variance, it pulls 9? Ive tested that circuit, and it does full value when grounded for a set time length then turns table off until input is cycled again. so not sure why its pulsing at consistant interval?
i need to go back and look see if there is a min spark advance table like OBDI pcms
