vats question
Old Sep 5, 2010 | 10:40 AM
armyracer11's Avatar
Default vats question
Ok so i just bought this car...it had a push button start and the security light was flashing. So i jumped the starter relay and now it will start with the but the light was still flashing.
i took out the gauge cluster and removed the bulb...now it doesnt start? Does the BCM not let it start without a bulb check?
oh it turns over just wont fire up.
Old Sep 5, 2010 | 11:07 AM
BaddBird's Avatar
What are you working on?
Old Sep 5, 2010 | 11:46 AM
1998 camaro
Old Sep 5, 2010 | 11:47 AM
another thing that is confusing me is that it doesnt do the run for 3sec and die...it just wont start at all
Old Sep 5, 2010 | 02:50 PM
badcoup's Avatar
the older pk systems inhibited the starter. Do a search on vats bypass, it a really simple procedure.
Old Sep 5, 2010 | 05:14 PM
well car just started working.....hmmmm! well i ordered vats bypass modual so i wont have any problems in the future.
Old Sep 6, 2010 | 12:49 AM
snake charmer's Avatar
just deleting vats from the car is one thing . the car has a body computer that can not be updated .
vats will throw a security light and lock you out of turning it on for 4 minutes .
the key if you got one has 1 of 13 gm resistance codes .
if you got the key measure the resistance and look at the 13 chart , spend $3 and be good vats is orange tube from ignition under kick panel .
