AFR setup
Old Sep 10, 2010 | 11:22 AM
BOTTLE ROCKET's Avatar
Default AFR setup
Million dollar question;
If I have a innovate LM-1, and use HP Tuners pro; why wouldn't my setup (offset) be exactly the same as everyone else's? What makes the different between setups?
I am having an AWFUL time setting up my wideband to read correctly in HPTuners, and just can't really get a clear answer as to how to do it (AND VERIFY). It just seems that if say; 5 volts and +9.6 works in one Innovate/Hp setup, it would work the same in all of them.
Old Sep 10, 2010 | 03:58 PM
badcoup's Avatar
I just did my lc-1 into non pro version using a writeup I found on here. worked great and was easy logged it through fuel tank pressure sensor input as I don't use tank press in my swap
Old Sep 10, 2010 | 04:09 PM
flintwrench69's Avatar
If you have the pro version why dont you run a wire into pin 1 of EIO connector on the side of your interface from your LM-1? It should be the analog output wire from your WB. I have an LC-1 & thats what I did.
Old Sep 10, 2010 | 04:57 PM
69LT1Bird's Avatar
Voltage issues and poor grounds are the differences.
Old Sep 10, 2010 | 06:14 PM
It's not a problem hooking it up and getting it to read, I just can't get it to read accurate in HPTuners. I watched the videos and have set (and adjusted and adjusted) my offset and can't get it my innovate readout the same as my HPTuners screen. If it agrees at stoich, it's off up high.
How the heck can you verify this thing???
Old Sep 11, 2010 | 08:52 AM
badcoup's Avatar
Ground your innovate to a point in the block where there is a PCM ground like the behind the intake manifold. I never had much luck with adjusting offsets and making it work properly. I fought this on my Porsche until I grounded the innovate and my smt6 together.
Old Sep 11, 2010 | 09:01 AM
Are you referring to the small un-shielded wire that goes into the #5 slot on the HPTuners?
I've been reading post forever on the HPTuners site, and obviously this is a issue that VERY few people have ever solved. I wonder why HPTuners creators can't set in and come up with something simple.
