PE commanded AFR leaning out at WOT??
The MAF is a bit jagged but if you look at the TPS, it actually follows it. This was a brake boost, launch, and spinning though 3 gears. He was peddling it the whole time, but when the TPS is flat the MAF levels out. Boost levels where probably all over the place.
It's a stock MAF. Why does he need a 2-bar?? He would max out a 2-bar too and HP Tuners doesn't have a 2.5-bar patch available for this OS. Any idea why the commanded AFR ratio changes while in PE?? That's really the only question I need answered.
Are you saying I should scale it more?? I was afraid to scale it too much so I figured scaling it back 20% would get us to 16 psi.
