Normal o2 mv range?
Wideband goes from 0 to 5000 mV, from 8 to 22 AFR aprox.
Your readings are ok. All oxygen sensors should switch from low to high volts to work properly. Don't expect a fixed mV reading for a given AFR, narrow band O2 don't work that way. Even in closed loop you will see them go from almost 0 to 900, like a sinus wave.
In open loop depends on the actual AFR. Any AFR lower than 14 will output 900 mV aprox.
Any AFR leaner than 15 will output 0mV aprox.
Stoich is around 450mV
If I have the Insufficient Switching codes shouldnt the mv numbers be all screwy?
I also have slow response code.
Seonsor 1 bank 1 is reading 930mv-960mv when car is full operating temp and idle. It dose change when the fans come on though. Also I have seen roughly 50mv-950mv when car is started. I think thats normal correct?
Now sensor 1 bank 2 is a different story. Its reading 430mv-450mv and staying 440mv-450mv most of the time. What can you tell me about this?
Codes I have on the car are pretty much normal for headers...
p0140
p0160
p1133
p1153
p0133
Can someone school me a little on what I should be seeing o2 in mv?
Isnt this not right? Is there a problem? Im just getting into all this scanning and im overwelmed from ignorance.
What could be keeping bank2 from oscilating?
p0140
p0160
p1133
p1153 = this is one for bank 2
p0133
Im thinking I need to test the wires. On bank 2. But I have codes for bank 1 and the o2 readings seem fine there.
