TPS throttle position sensor fluctuating after its cleared HELP hp tuners
My throttle position sensor is fluctuating after its zero'd out HELP!!!
I do the unplug the tps turn the key on for 10 - 20 seconds and then turn
the key off then plug it back in and turn the key on clear the code it set
and in hp tuners it says 0.0 0.0 0.4 0.0 0.4 for my tps %
and then ounce in while its gets a wild hair up its butt and flashes me a 0.8
I have tried 2 different brands of tps sensors and they both basicly did the
same thing 1 actually zero'd out with the engine off and then when you turn
the engine on or go for a drive ITS BACK!!! any remedy for this
thanks!
I am using a texas speed and performance PTM 92mm throttle body
Iac counts are 50-60 ish when hot. this is on a 1998 formula automatic
thanks!
thanks!
thanks!
It would greatly help to post a run log and tune.
man it does it with the tps disconnected too lol
when I scan it in hp tuners it fluctuates doesnt even have to be conected lol
floored it shows 100% then pedal released 0% 0.4% 0% etc
so I figure i woudl try and scan it with it disconnected
LOL its doin the same thing
![Argh](https://ls1tech.com/forums/images/smilies2/argh.gif)
