Newbie has question regarding custom tune
Old Nov 12, 2010 | 06:28 AM
williambmac's Avatar
Default Newbie has question regarding custom tune
I have a 2001 camaro with some aftermarket goodies (cam, afr heads,kooks header,msd). However I am running into a problem. Ever since I had the work done, I keep getting a p0135 bank 1 sensor 1, p0162 bank 2 sensor 2 heater circuit, I have replaced both o2, checked the eng sens fuse, checked all of the wiring and grounds back to the pcm, all o.k.
I am also having a problem with the reverse lockout solenoid on my t56 trans, it's constantly engaged. I always need both hands to get it into reverse.
I checked power to the soleniod, o.k., but the ground path back to the pcm appears to be the problem, no broken wires.
The ground path is activated by the pcm, that is what activates and deactivates the solenoid, correct?
My question is the guy that did the work to the car also did custom tuning to it. He did alot of modifications in the computer. Could he have shut anything off in the pcm that would create these problems. I am not that knowledgible with the computer tuning, but I know he did something with the skipshift and I believe they are on the same ground circuit.
Anyone have any ideas. I have spent alot of time going through the wiring, checking grounds, ohming stuff out and checking continuity but can't find anything wrong. Thanks.
Old Nov 12, 2010 | 07:31 AM
Mister Gray's Avatar
I'd ask for my money back and get a new tuner....
Old Nov 12, 2010 | 03:47 PM
Aside from the obvious......can you shut off the reverse lockout when doing a custom tune.
The car does run really well aside from these two issues.
I have also heard that lt headers can cause O2 sensor heater issues.
Old Nov 12, 2010 | 06:03 PM
DynoDR's Avatar
And why is that?
tuner....
Old Nov 12, 2010 | 08:27 PM
Originally Posted by DynoDR
And why is that?
Did a search here, numerous threads stating that long tube headers do not allow 02 heater circuits function properly.
https://ls1tech.com/forums/generatio...ough-tips.html
https://ls1tech.com/forums/generatio...blems-lts.html
https://ls1tech.com/forums/pcm-diagn...-p-0135-a.html
Old Nov 15, 2010 | 04:34 PM
Can anyone tell me if you can screw up the reverse solenoid circuit while doing a custom tune. My reverse solenoid is enabled and I have a very difficult time getting the car into reverse. Thanks.
Old Nov 15, 2010 | 06:59 PM
2xLS1's Avatar
No a tune cannot screw up the reverse inhibit. Check the 12V again. The O2 heaters and reverse inhibit solenoid are powered off the same circuit. (Eng Sen)
https://ls1tech.com/forums/12064586-post7.html
Old Nov 15, 2010 | 07:46 PM
Originally Posted by 2xLS1
No a tune cannot screw up the reverse inhibit. Check the 12V again. The O2 heaters and reverse inhibit solenoid are powered off the same circuit. (Eng Sen) [/url]
I have checked voltage at the pink wire and I get 11.87 volts key on. Zero volts key off.
I have checked the ground wire from the connector back to the pcm @ circuit #44 and it is good. Could it just be that the pcm is bad?
I am starting to beat my head on this one. Everything leads me back to the pcm. The pcm enables the ground circuit to deactivate the solenoid correct (unlocks reverse)? It then opens the ground circuit to activate the solenoid (locks out reverse)?
Old Nov 15, 2010 | 08:37 PM
2xLS1's Avatar
I may be wrong about what I said about your tuner not being able to screw up your reverse inhibit. I never noticed it because I have never changed those settings, but looking at a 01 M6 cal with HP Tuners there are reverse lockout settings. Perhaps he changed those thinking he was disabling the Skip Shift which are on the same page. These are the stock settings for the reverse lockout.
Old Nov 16, 2010 | 06:41 AM
Thanks alot. I will show this to the tuner and have him hopefully make adjustments to correct this. I was really getting frustrated over this.
Old Nov 16, 2010 | 06:46 PM
And why is that?
Merely busting chops everyone
Old Nov 17, 2010 | 07:44 AM
2xLS1.......Thank you for the info. It corrected the problem.
Now I just need to deal with the o2 heater codes that won't go away.
Old Nov 17, 2010 | 09:14 AM
2xLS1's Avatar
http://www.gearchatter.com/viewtopic9158.php
Old Nov 17, 2010 | 09:47 AM
Frost's Avatar
wow you had to tell your tuner how to fix the reverse lockout issue that he caused??
