What is to much TPS Voltage and Whats Not enough TPS Voltage?
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Ok I am trying to dial in my IAC by opening up the Blade with the screw on my 90 mm TB ,But by doing so I have .65-.67 Idle Voltage but got 4.5 Volts @ WOT.I tried opening up the TPS holes to lower voltage at Idle get it set to .47 volts and WOT is only 4.2 Volts.
Is .65 volts ok or is it screwing things up?I run Open Loop only ,Closed loop turned off...TIA
__________________
__________________
there is no too much from my point of view. You can adjust the low limit by tuning, I can tell you how via Efilive or Hptuner.
I have the same question. I'm doing some tuning & tried to open up my set screw a little. When I do, my TPS voltage reads higher than .6. The tuning guides say to keep it between .4 & .6 at 0% TPS. How can I adjust the blade out a little & reset the TPS voltage to get it back down at 0% TPS? Or is it okay if it's up in the .65-.70 range?
