aggressive tune vs. conservative tune?
I was wondering what is the difference and performance difference between both of these tunes? I plan on adding heads and a fast intake and getting retuned.
One shop i called local from me said that they do a pretty conservative tune. Any idea what that actually means? When i think of conservative tune, im thinking of giving up a few hp?
If they mean any less aggressive than the first I would discuss with them why. Either way it sounds like they might lean more towards a set method of tuning rather than trying to find out what the car really wants to make the best power.
That might not be the case but the way you worded it, that's the impression I get in my mind.
You should have asked this question to your tuner IMO. His answer is the one that matters.
Then again make sure conservative doesn't mean lazy.
I will give them a call to discuss more. But when i just first called to get pricing on a tune, they did say that they tend to do more of a conservative tune because they dont feel the need to put any wear and tear on the engine for a few more HP.
one barely relevant reference (a Subaru motor if I recall)
is the relation between MBT and ping-onset timing. That
is something that would be deducible from a dyno pull
series if it was broad enough. It would be a nice useful
rule of thumb for the shade tree tuner; run it up to KR
and then pull out N degrees (probably varies by RPM
and build, but still).
The Subaru writeup I think was saying -2 - -3 degrees,
which is kind of edgy in my book.
Any thumbs?
Any thumbs?
and ping point I'm interested in (the latter being easy to
determine, the former requiring you so sit on the rollers
at time=money.
I then go and test it on a steep 5 degree 2 mile uphill by my house, leaving the car in 3rd and doing some pulls from 40-80mph 3.73's making the motor work hard in the midrange.
I don't know if it's the right way but it's my conservative tune.
