ABS delete.....
Old Feb 6, 2004 | 04:55 PM
2001CamaroGuy's Avatar
Default ABS delete.....
I have bypassed the ABS module on my 01 Z28 (non traction control car) and am running manual brakes. The problem is that I don't know how to "trick" the computer into thinking the ABS unit is still there. If I unplug the unit, the "ABS INOP", "BRAKE", and "SERVICE VEHICAL" lights all come on. I don’t want to just “put a piece of tape over the lights” (or remove them) as that kind of stuff bothers me (half assed). What do I do?
Old Feb 6, 2004 | 10:40 PM
2xLS1's Avatar
You remove your ABS but you have problems with removing a few bulbs? What was your the logic behind bypassing the ABS module?
Old Feb 6, 2004 | 10:44 PM
if you READ my first post, I think its pretty straight forward why I don't want to just "pull bulbs"....I said "that’s half assing it" ...I like things FIXED!
I have changed every suspension part on the car except for the steering rack its self and the ABS was not allowing me to take full advantage of it. By removing it and installing a proportioning valve I get:
a) faster responding brakes
b) better tuned braking
Old Feb 7, 2004 | 02:36 PM
well I found that if I removed the electrical part of the ABS unit from the heavy (and large) valve body/pump section, I could leave the electrical part connected which turned off the lights/codes yet fit under the fuse box (out of sight). I'm still looking for a better way to do it, but for now that will work.
Old Feb 7, 2004 | 03:45 PM
cablebandit's Avatar
i will have to remember that
Old Feb 7, 2004 | 04:54 PM
its easy to do......I couldn't believe nobody had ever mentioned it before
remove 6 screw, plug the electrical connector back in, and stick it out of the way
Old Feb 9, 2004 | 09:43 AM
smokinHawk's Avatar
is there a way to turn off the abs in edit?
my 12 bolt doesnt have ABS and i plan on getting rid of the block will the light still be on?
Old Mar 1, 2004 | 05:18 PM
MYTURBOT/A's Avatar
Cool di you use a standard GM proportioning valve, or how did you do it?
