98 to 99+ PCM Question
Old Jan 13, 2011 | 11:32 AM
  #61
Frost's Avatar
The picture shows the connector, only the text is rubbed off.
Old Jan 13, 2011 | 12:19 PM
  #62
Punisher_ws7's Avatar
ok then whats that bottom connector?
  #63
bigboykilroy's Avatar
Punisher I see what you mean.
The person you got your PCM from gave you 1 of the 2 pcm connector blocks. (The 02 and the 98 are the same blocks)
You can use it to help with repinning. Just save it incase you mess up one of yours.
I prefer to label the wires on the pcm blocks with a ptouch labeler (r1, R2, R3)
It takes extra time but its very reliable.
Then I reverify one more time.
Then take off the red and blue connector holders and use a small punch and pick up the white tabs and pull out the wires.
Then you take you wires and start with one block and repin that connector.
Then to the other.
PM me of you need help.
Old Jan 13, 2011 | 01:04 PM
  #64
ok thanks bigboykilroy, and i'll be sure to holler at ya,, but i think my tuner wants to do it when he builds my start up tune..
Is there any market for the 98 pcm's
Old Jan 13, 2011 | 09:08 PM
  #65
If you tuner needs the sheets on the pin swap let me know and I will email them to you.
There really isnt that much performance market for the 98 pcm, it can be done but there are more optins out there for the newer PCM's.
Now there is a guy on here that buys the 98 pcm;s for like 125.00 not bad.
Old Jan 14, 2011 | 12:21 PM
  #66
Punisher if you need a 2nd PCM connector give me a PM with your shipping address, I have a few and I will send you one.
Old Jan 20, 2011 | 02:05 PM
  #67
RGSS's Avatar
Is there a real advantage of the 12200411 PCM over the 9354896 PCM in terms of harware or capabilities? Does it even make a difference in the operation or tuning of the engine?
Reason i am asking is because I am doing an LS swap in my LT Camaro. I have a 2000 harness and 9354896 PCM and could opt for the 0411.
Old Jan 20, 2011 | 03:24 PM
  #68
Basically the 0411 has a faster processor than the 4896 PCM and some of the internal memory was moved around.
Old Jan 20, 2011 | 04:22 PM
  #69
Camaro98Z/28's Avatar
wheres everyone getting the repin diagram for the 98 to 99+ swap? I found lots of info on the swap but not actually how to do it.
Thanks!
Old Jan 21, 2011 | 01:59 AM
  #70
bighamz28's Avatar
+1
Old Jan 21, 2011 | 10:34 AM
  #71
i have a great re-pin guide if you need it just pm me you email address.
I plan on trying up a guide here very shortly.
Old Jan 30, 2011 | 03:16 PM
  #72
livewire0201's Avatar
Originally Posted by bigboykilroy
You will need to have the 2002 pcm have the fuel segment swapped into it for the fuel gauge to work correctly.
Since you are using you 98 auto harness you will need to do nothing to sensors or anyting else.
The fuel segment is only for the fuel gauge to make it work properly? The temp sensors are different? I'm running a 98 ls1 t56 in a 62 nova. I want to upgrade to the 02 pcm for tuning capabilities.
The 98 computers don't use water temp but the 99+ does? Do i need to get a 2 wire sensor and connector to make this work? What other sensors are different?
Are the crank sensors different (from 24x to 58x or something)?
Other than repinning the harness at the connectors it is more or less plug and play?? Thanks
Old Feb 1, 2011 | 12:11 AM
  #73
The fuel segment swap is to get the gauge working properly with the 98 cluster.
The 98's drive the gauge cluster directly off the sensors.
For the 98 temp sensor, it had 3 wires, one is signal, one is ground and the other drives the gauge. (yellow signal, Brown Ground)
Crank sensor is the 24x so no difference form 98 to 04
repin the harness, plug in prepped 0411 pcm (if you are using a 98 harness), enjoy = ; )
Old Feb 19, 2011 | 04:57 PM
  #74
s/c'd cav's Avatar
what do i need to swap my 99 to the 02 computer ?
