c5 corvette tuning question
The other day just for the hell of it, I hooked my handheld diablo to the car as I drove and decided to monitor my driving conditions. I did notice that my LTFTs were in the -12 to -10 range. Should I trust his judgement and leave it be, or should I adjust the pe ratio myself and bring it up to the -2 to 0. Range? I remember seeing on diablo tuning that almost 0 is best, but the tuner used hp tuners so I assume that the diablo is not as accurate?
Adjusting the PE ratio won't change your closed loop fueling.
The FTs should be a bit closer, but if it's running OK, I don't know if I'd bother with it. If you're that concerned, how bout contacting your tuner and asking him about it, and see if he can't dial them in a bit closer.
I adjusted my injector slope to bring the ltfts more evenly....
