Best Wide Band Controller to use with HP tuners Pro
FWIW, I'm using one of the older JAW 1.042 DIY units. Either I'm doing something wrong, or the 1-5v output is just impossible to match to the display. Makes me wonder which output source is accurate (if either).
I've re-calculated the error in the VCM scanner at least 3 times. I'll try another time or 2 and end up buying something else if I can't get a better correlation.
The only bad thing about the LM-2 is I have to recalibrate it for every car I tune. Don't know why but calibration changes even from one day to next (same car).
Once calibrated, it works fine and AFR always agrees with narrowbands once finished.
Many people talk good things about AFX, I'm going to buy one to compare...
