Is it safe to run motor with no O2's
Old 02-21-2011, 10:11 PM
bfrank79's Avatar
Default Is it safe to run motor with no O2's
Its a LY6, straight headers right now, wondering if i can drive it to the exhaust shop with the O2's disconnected, will it run right and is it safe?
Old 02-22-2011, 01:47 AM
remauto1187's Avatar
Can't say as i have tried it but....
When you first start your engine up you are running rich and in open loop...the computer is ignoring your oxygen sensors because they haven't heated up yet. O2 sensors have a heater built-in to them which is needed for the sensor head to properly put out a millivolt signal that is proportional to the amount of oxygen its head is exposed to in your exhaust stream.
My vote is no...it wont hurt it...it will get horrible mileage. It should mimick a carbed engine with the choke stuck on once the engine is warmed up enough to where it should have gone into closed loop mode.
Old 02-22-2011, 06:57 AM
Sid447's Avatar
Yes, it'll run.
and get you from a to b okay.
Old 02-22-2011, 08:21 AM
LS1Tech Sponsor
Slowhawk's Avatar
It can load up with fuel.
Old 02-22-2011, 09:31 AM
LSX Mechanic
Damian's Avatar
Best case scenario is it'll just dump a ton of fuel and get 8mpg. Worst case it'll foul the plugs depending on how far you drive it. But it can be done and it's not going to kill the motor. The PCM has back up parameters in case sensors fail.
Old 02-22-2011, 01:20 PM
James Linder's Avatar
you could buy the O2 sensor wiring harness extenders and plug them in before driving to the shop; they are going to have to install these when you get there anyway and it only takes about 5 minutes to plug everything in. You will know how well it runs without them only by trying; no one can predict exactly what will happen with your specific setup.
Quick Reply: Is it safe to run motor with no O2's
