What is tunable?
Old Feb 24, 2011 | 09:28 PM
Big Al's Avatar
Default What is tunable?
Where can I find a list of what is programmable on a 95 Z28? Have a TH400 and a S-60. (on the way) Need to find out what I can turn off and what I have to live with. Also need to modify the fuel delivery and so on.
Perhaps there is something already here someone can point me to.
Al
PS. Anyone know of a good Electromotive forum for my OT car? Mine is kicking my ***.....
Old Feb 24, 2011 | 09:39 PM
2xLS1's Avatar
Without spending any money, download and install TunerPro and the EE definition file. You can find it with google. Then unzip and open either one of these bin files. You can then see everything you can change. You will need to buy an OBD1 cable to flash the PCM
File Type: zip
File Type: zip
Old Feb 25, 2011 | 04:01 PM
TunerGuy's Avatar
ECM Switch Parameters
VATS Select (F+B-Body) (X = Enabled)
VATS Select (Y-Body) (X = Enabled)
Data Stream Fuel Enable (X = Enabled)
Traction Control (X = Enabled)
C.A.R.S. Select (X = Enabled)
Speed Density Mode (X= Enabled)
Crank AIR Select (X = Enabled)
TCC Enable/Disable (X=Enabled)
TCC Release at Low TPS (X=Enabled)
TCC Release with Rapid TPS Decrease
Gradual TCC Release (X=Enabled)
Downshift Turns TCC Off (X = Enabled)
Upshift Turns TCC Off (X = Enabled)
Automatic Trans. Option (X = Enabled)
Turn Off TCC if ASR On (X = Enabled)
Force Manual Mode in D2 (X = Enabled)
ASR Downshift Inhibit (X = Enabled)
ASR Upshift Inhibit (X = Enabled)
Shift Solenoid A - 1st Gear (X=Enabled)
Shift Solenoid A - 2nd Gear (X=Enabled)
Shift Solenoid A - 3rd Gear (X=Enabled)
Shift Solenoid A - 4th Gear (X=Enabled)
Shift Solenoid B - 1st Gear (X=Enabled)
Shift Solenoid B - 2nd Gear (X=Enabled)
Shift Solenoid B - 3rd Gear (X=Enabled)
Shift Solenoid B - 4th Gear (X=Enabled)
Injector Fault, Cylinder 1, Error 1
Injector Fault, Cylinder 2, Error 2
Injector Fault, Cylinder 3, Error 3
Injector Fault, Cylinder 4, Error 4
Injector Fault, Cylinder 5, Error 5
Injector Fault, Cylinder 6, Error 6
Injector Fault, Cylinder 7, Error 7
Injector Fault, Cylinder 8, Error 8
MALF Indicator Lamp Fault, Error 11
No DRP Fault, Error 12
Left O2 Sensor Failure, Error 13
Low Res. DRP Failure, Error 16
Injector Intermittent Fault, Error 18
Injector Failure, Error 19
TPS Sensor High, Error 21
TPS Sensor Low, Error 22
MAT Sensor Low Failure, Error 23
Vehicle Speed Diagnostic, Error 24
MAT Sensor High Failure, Error 25
CCP Electrical Failure, Error 26
EGR Electrical Failure, Error 27
Trans. Range Control Circuit, Error 28
Air Pump Diagnostic, Error 29
EGR Diagnostic, Error 32
High MAP Diagnostic, Error 33
Low MAP Diagnostic, Error 34
Hi Res DRP Diagnostic, Error 36
Brake Switch Shorted Diag, Error 37
Brake Switch Open Diag, Error 38
Spark System Open Diagnostic, Error 41
Spark System Diagnostic, Error 42
Knock Sensor Diagnostic, Error 43
Left O2 Sensor Lean, Error 44
Left O2 Sensor Rich, Error 45
VATS Diagnostic, Error 46
Missing Spark Module, Error 47
MAF System Diagnostic, Error 48
Oil Temp. Low Diag - Error 52
System Voltage High, Error 53
Fuel System Lean, Error 55
Trans. Temperature High Diag, Error 58
Trans. Temperature Low Diag, Error 59
A/C Low Charge Diagnostic, Error 61
Oil Temp. High Diag - Error 62
Right O2 Sensor Fail, Error 63
Right O2 Sensor Lean, Error 64
Right O2 Sensor Rich, Error 65
A/C Press Sensor Diagnostic, Error 66
A/C Press Sensor Diagnostic, Error 67
A/C Relay Diagnostic, Error 68
A/C Clutch Diagnostic, Error 69
A/C Clutch Relay Diagnostic, Error 70
A/C Evap. Temp. Diagnostic, Error 71
No Vss Signal Diagnostic, Error 72
Force Motor Current Diag, Error 73
Traction Control Diagnostic, Error 74
Trans System Voltage Diag, Error 75
Fan 1 Diagnostic, Error 77
Fan 2 Diagnostic, Error 78
Trans Fluid Temp. High Diag, Error 79
Transmission Slip, Error 80
Trans Shift 'B' Diag, Error 81
Trans Shift 'A' Diag, Error 82
TCC Control Feedback Diag, Error 83
3->2 Downshift Feedback Diag, Error 84
TCC Stuck On Diagnostic, Error 85
TCC Enable Error Diagnostic, Error 90
Shift Light Diagnostic, Error 91
Oil Life Diagnostic, Error 95
Oil Level Diagnostic, Error 96
Vss Signal Diagnostic, Error 97
ECM Constants
Cylinder Volume
Injector Flow Rate
Display Injector Flow Rate
MAP Threshold To Enable WOT
Cool Thresh For TPS For WOT (HighTemp)
Min. Cool. Temp. for Closed Loop
Min Cool Temp for Closed Loop, Cold MAT
Cold Closed Loop Timer Threshold
Hot Closed Loop Timer Threshold
Minimum BLM
Maximum BLM
Minimum Keep-Alive BLM
Maximum Keep-Alive BLM
BLM Cell MAP Boundary Hysteresis
BLM Cell RPM Boundary Hysteresis
Individual Cyl. Fuel Trim Disable %TPS
Minimum Injector Pulse Width
Hi Temp Enrich Enable Coolant Temp.
Hi Temp Enrich Disable Coolant Temp.
High Coolant Temp. Min. Enrich AFR
High Temp. Enrich Enable Delay
Baro Update RPM Threshold
EGR Enable, Min. MAP
EGR Enable, Min RPM
EGR Enable, Max RPM
EGR Enable Cool. Temp (Hi Startup MAT)
EGR Enable Cool. Temp (Low Startup MAT)
Fan Temp. Hysteresis - Low Vehicle Speed
Fan Temp Hysteresis - High Vehicle Speed
Fan High/Low Vehicle Speed Threshold
Fan 1 On, Oil Temp, (Low RPM)
Fan 1 On, Oil Temp , (High RPM)
Fan 2 On, Oil Temp, (Low RPM)
Fan 2 On, Oil Temp, (High RPM)
Fan Enable, (High RPM, High Oil Temp)
Fan 1 On High A/C Pressure Threshold
Fan 1 Off High A/C Pressure Threshold
Fan 1 Disable MPH, High A/C Pressure
Fan 1 Enable MPH, High A/C Pressure
Fan 2 On High A/C Pressure Threshold
Fan 2 Off High A/C Pressure Threshold
Fan 2 Disable MPH, High A/C Pressure
Fan 2 Enable MPH, High A/C Pressure
Fuel Cutoff Speed
Fuel Resume Speed
Fuel Cutoff, 1st Gear
Fuel Cutoff, 2nd - 6th Gear
Fuel Resume, 1st Gear
Fuel Resume, 2nd - 6th Gear
Error 32, Min Diff. MAP Test Value
Speedometer Scalar
Speedometer Scalar, Fraction
Speedometer Scalar, (Scan Tool)
Speed Pulses Per Driveshaft Revolution
Time Between Pulses For 'Stop'
Canister Purge Enable Cool. Temp.
Min. Coolant Temp. For CAT Protect
Min. Coolant Temp. To Enable C.A.R.S.
Speed Threshold To Enable C.A.R.S.
Speed Threshold To Disable C.A.R.S.
RPM Threshold To Disable C.A.R.S.
%TPS Threshold To Disable C.A.R.S.
Low PRNDL Upshift Speed Threshold
Low PRNDL Downshift Speed Threshold
Maximum Line Pressure
Kickdown Mode Enable TPS Threshold
Kickdown Mode Disable TPS Threshold
DFCO Enable RPM Threshold
DFCO Disable RPM Threshold
DFCO Enable MAP Threshold
DFCO Disable MAP Threshold
DFCO Disable RPM Decrease Threshold
DFCO Enable Coolant Temp. Threshold
DFCO Enable MPH Threshold
DFCO Enable Delay Timer
DFCO Spark Retard
Knock Retard Enable Coolant Temp.
Burst Knock Enable %Diff Air Flow Thresh
Burst Knock Enable Coolant Temp. Thresh.
Low Octane Comp. Attack Gain MAP Enable
Low Octane Attack Gain Delta MAP Disable
Low Octane Compensation Decay Gain
Spark Advance Table Bias
Spark Coolant Temp Correction Bias
Spark Reference Angle
Maximum Spark Advance
Min. Coolant Temp. To Enable Air Pump
Closed Loop Idle Enable Vehicle Speed
IAC Power Steering Anticipate Correction
A/C Clutch Disable %TPS Threshold
CAT Overtemp Threshold (Low Baro)
CAT Overtemp Threshold (Mid Baro)
CAT Overtemp Threshold (High Baro)
CAT Overtemp AFR
TCC Upshift Off Time
TCC Downshift Off Time
Vss Diagnostic Enable Min RPM
Tach Signal High Period
TunerGuy's Avatar
Tables
ECM Switch Table
ECM Constant Table
Main Spark Advance Vs. RPM Vs. MAP
Extended Spark Advance Vs. RPM Vs. MAP
Spark Correction Vs. MAP Vs. Coolant Temp.
Closed TPS Spark Advance Vs. RPM
Minimum Spark Advance Vs. RPM
Crank Spark Advance Vs. Coolant Temp.
Knock Fast Attack Rate Vs. RPM
Knock Retard Recovery Rate Vs. RPM
Max. Knock Retard Vs. RPM (in P.E.)
Max. Knock Retard Vs. MAP (not in P.E.)
Burst Knock Retard Vs. Coolant Temp.
Low Octane Compensation Attack Gain Vs. RPM
Low Octane Knock Retard Multiplier Vs. RPM
Low Octane Knock Retard Multiplier Vs. MAP
Low Octane Knock Retard Multiplier Vs. Cool. Temp.
Traction Control Spark Retard Vs. RPM
EGR Spark Advance Correction Vs Vacuum Vs RPM
%TPS Threshold For WOT Vs. RPM Vs. Cool Temp
Volumetric Efficiency Vs. RPM Vs. MAP
Volumetric Efficiency Vs. RPM Vs. MAP (Ext.)
Inverse Temperature Correction Term Vs. MAT
Crank Volumetric Efficiency Vs. %TPS Vs. RPM
Injector Offset Vs. Battery Voltage
Low Pulse Width Injector Offset Adder Vs. BPW
%Change To Fuel/Air Ratio Vs. Cool. Temp. at WOT
%Change To Fuel/Air Ratio Vs. RPM at WOT
Open Loop AFR Vs Coolant Temp. Vs. MAP
Closed Loop Fuel Timer Vs Coolant Temp.
BLM Cell RPM Boundaries
BLM Cell MAP Boundaries
Individual Cylinder Fuel Trim Multiplier
Fast O2 Rich/Lean Threshold Vs. CL Mode
CL Mode Value Vs. AirFlow
DFCO Enable %TPS Threshold Vs. RPM
DFCO Exit Spark Blending % Vs. TPS
IAC Target RPM Vs. Coolant Temp Vs. Gear
IAC Park Position Vs. Coolant Temperature
IAC Offset for A/C Anticipate Vs. A/C Pressure
Idle Overspeed Spark Retard Vs. RPM Error
Idle Underspeed Spark Advance Vs. RPM Error
Throttle Follower IAC Offset Vs. MPH
Crank AFR Vs Distrib. Refer. Pulse Vs Cool. Temp.
Extended Crank AFR Vs DRP Vs Cool. Temp.
Prime Pulse Width Vs. Coolant Temp.
Added Prime Pulse Width Vs. Coolant Temp.
Added Prime Pulse Enable Crank Time Vs. Cool. Temp
Initial Startup AFR Enrichment Vs. Coolant Temp.
Fan Enable Coolant Temp Vs. Speed
Normal Mode Up/Down Shift Points
Performance Up/Down Shift Points
Manual Mode Up/Down Shift Points
Cruise Mode Up/Down Shift Points
Kickdown Mode Up/Down Shift Points
Cold Mode Upshift Speed Modifier Vs. %TPS
Kickdown Normal Mode Shift RPM Thresholds
Kickdown Mode Shift RPM Thresholds Vs. Mode
Main Line Pressure 0 - 64 MPH
Main Line Pressure 64 - 128 MPH
Line Pressure Modifier In WOT Vs RPM
Line Pressure Offset Vs %TPS Vs Gear (Norm Mode)
Line Pressure Offset Vs. %TPS Vs. Gear (Perf Mode)
Line Pressure Offset Vs %TPS Vs Gear (Manual Mode)
Line Press Mod Vs. %TPS Vs. Trans. Temp, 2nd Gear
Line Press Mod Vs. %TPS Vs. Trans. Temp, 3rd Gear
Line Press Mod Vs. %TPS Vs. Trans. Temp, 4th Gear
Down Shift Pressure Modifier 2 -> 1 Vs MPH
Down Shift Pressure Modifier 3 -> 2 Vs MPH
Down Shift Pressure Modifier 4 -> 3 Vs MPH
Garage Shift Press Vs Trans Temp Vs RPM - Drive
Garage Shift Press Vs Trans Temp Vs RPM - Reverse
Force Motor Current Vs Press Vs Trans Temp, + Chng
Force Motor Current Vs Press Vs Trans Temp, - Chng
Shift Time Vs. %TPS Vs. Shift, Normal, Low Alt.
Shift Time Vs. %TPS Vs. Shift, Normal, High Alt.
Shift Time Vs. %TPS Vs. Shift, Perform., Low Alt.
Shift Time Vs. %TPS Vs. Shift, Perform., High Alt.
Reverse Lockout Enable/Disable Speeds
TCC Normal Mode Engage MPH Vs. Gear Vs. %TPS
TCC Normal Mode Release MPH Vs. Gear Vs. %TPS
TCC Manual Mode Engage MPH Vs. Gear Vs. %TPS
TCC Manual Mode Release MPH Vs. Gear Vs. %TPS
TCC Hot Mode Engage MPH Vs. Gear Vs. %TPS
TCC Hot Mode Release MPH Vs. Gear Vs. %TPS
TCC Performance Mode Engage MPH Vs. Gear Vs. %TPS
TCC Performance Mode Release MPH Vs. Gear Vs. %TPS
TCC Cruise Mode Engage MPH Vs. Gear Vs. %TPS
TCC Cruise Mode Release MPH Vs. Gear Vs. %TPS
TCC WOT Forced Lock Speed Threshold Vs. Gear
TCC Off Time For Shift Vs Shift
TCC Apply Operating Point Vs. %TPS Vs. Gear
TCC Apply Rate Vs. Gear Vs. %TPS
TCC Release Operating Point Vs. %TPS Vs. Gear
TCC Release Rate Vs. Gear Vs. %TPS
MAF Sensor Calibration Table 1
MAF Sensor Calibration Table 2
MAF Sensor Calibration Table 3
MAF Sensor Calibration Table 4
Old Feb 26, 2011 | 02:09 PM
Big Al's Avatar
Tuner Guy,
I'm overwhelmed! Thanks, I'm going to copy and past this so I can always find it.
What is the best way to change these parameters? Need to disable some stuff that has to do with the 4L60E and abs sensor that gone.
Al in Tucson
95 Z28, TH400, soon to be S-60 w/4.30's
Old Feb 26, 2011 | 04:49 PM
TunerGuy's Avatar
Originally Posted by Big Al
Tuner Guy,
Al in Tucson
If you're asking what software package for most OBD1 stuff I use TunerCat even though I also have TunerPro, since it seems to be more accepted in the SyTy world. Either one of the should do the same job, its which ever one you like the best, TC also has a demo version on his web site, but it only does the 747 ECM, but you can get a good hang of if you like the interface from it. I personally like TC better, but I have a lot more experiance with it. I think Craig Moates sells the TunerPro set up
Old Feb 26, 2011 | 05:25 PM
2xLS1's Avatar
TunerPro is free. So are the definitions.
Old Feb 27, 2011 | 09:21 AM
TunerGuy's Avatar
Actually, it is given on the honor system, you can try it for free and use it, as long as you you like, without paying as long as you don't mind delay banners popping up every time you start it. I felt the guy did a good job with and paid to register it. So it isn't really free, at least not to honest people, How long do you think Mark is going to keep supporting and improving it, if nobody gives him a return on his time and money he invested, in developing this?
Old Feb 27, 2011 | 10:31 AM
2xLS1's Avatar
Welcome to TunerPro.net. TunerPro is a free, donate-if-you-like-it tuning platform aimed at making tuning easier and cheaper. TunerPro started life in early March of 2003 and was originally created to tune GM vehicles between model years 1985 and 1995. TunerPro has since grown into a very robust tuning tool and is evolving faster than ever. This project started as an educational project with a few simple goals: It should be available for free in its essence, it should be better than whats available in its class, it should remain as simple as possible to use, and it should be fun for me to develop. TunerPro will continue to grow and evolve. I hope to continue to add support for other automobile (and maybe non-automobile?!) platforms out there. Please stay tuned!
Sounds pretty free to me. Donate, not pay for it if you like it. Sounds like as long as he is having fun doing it he will continue, donations or not. I help people all the time for free with car and truck problems and I have fun doing it. I don't consider the ones who don't donate something to me for helping them dishonest.
Hey Poconojoe, I thought you got banned.
Old Feb 27, 2011 | 10:45 AM
TunerGuy's Avatar
If you didn't like it, would still use it, its back to your lack of honesty. Of course, you've shown you don't know some other things, you think you do.
