99 5.3 pcm into 99 m6 f-body
Ok guys, I'm having a few issues here. I recently swapped a pcm from a 99' automatic 5.3 silverado into a 99 m6 ls1 f-body because the original computer took a dump on me and we had an extra laying around. It was my understanding that the pcm's are the same/minimal differences so they are interchangeable. I copied all the differences over from the ls1 pcm to the 5.3 pcm and it started and seems to run decent. I'm having issues with the check engine light refusing to go off, no matter what DTC's i turn off, the airbag light's on, traction control doesn't work(which i assumed it wouldn't) but most importantly its very hard to get into reverse now. I assume thats because its an auto pcm. What are my options here? Will I have to take it to the dealership and have them flash a 99' OS? If so, will I have to re-license the computer after doing so? I just really don't want to have to license another computer just to use it's OS.
-Garrett's Final Tune- 5.3 pcm with Ls1 tune on it.
-Garrett's 99 ls1 cabot tune- Original ls1 tune file.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Your problem is the auto shares pins with the manual and some of those pins have different functions (reverse lockout, TCC, skip shift, shift solenoids, etc.) depending on the tune. 4L60E's have a different transmission pinout than 4L80E's and manuals are different again.
Yes, exactly. I realize I did it improperly, but the car broke down on the side of the road and we needed a way to get it home. It was cheaper to write the 5.3 pcm that i already had than to pay a tow bill. I just really hate to waist $100 on a tune in the repository, or the shitty old factory pcm to do a full reflash. I'll email support and try to get the transmission segment swap and see if that works.
Also, if I do a full reflash will the reverse lockout work? Or if I take it to the dealer and have them do a stock reflash will I have to re-license the pcm?
Ok, that sounds like a plan. I just really wanted to make sure the reverse lockout and everything will work just fine with a 5.3 pcm with an ls1 OS. I knew that was the best option, but a guy that dyno tunes in memphis told me that in order to use the 5.3 pcm i would have to repinn it for reverse. I thought he was wrong, just wanted verification.
Again I agree. I would take his advice, I would be willing to bet this man has successfully tuned more cars than Richard Petty has won NASCAR races...
[/QUOTE]
Haha Frost is definitely the man. He actually originally tuned the car a few cam/motor swaps ago
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
When i use the 99 and newer engine harness in the 98 cars for the swap there are about 6 wires that need to be wired into the pass side kick connector (under the glove box).
I just want to be clear, some think they can get a 99 harness swap it on a 98 and they are done. And that is not the case.
Can you please clarify?
