LC1 Lagg using non-EIO
Using HPT and Innovate LC1 WB with XD-16. I am logging the LC1 in HPT using the AC Pressure sensor and I have it grounded to the battery.
My question is, does anyone else use the AC pressure sensor and are they seeing a lagg in the resolution/response time of the LC1?
When I look at the LC1 in Logworks it is updating very quickly, but when i look at it in HPT through my custom PID i believe its about two cells off. As an example, in HPT i bump the throttle, if I look at the MAP sensor kpa it shows me 80 (normally 66 at idle), and about two cells later i see the spike on my LC1 in AFR from about 14.0 to 15.1. I would have thought that these two would correlate with each other, but it looks as if there is some lagg in the readings.
Is this normal? Do i need to just manually adjust for this or this just lagg I am seeing in distance of the MAP sensor and WB (in Y pipe).
My WB is programed to update at the 1/6 rate. I thought this was the correct rate, but does it need to be instant?
Thanks for any help!
