cold start question
Old Apr 18, 2011 | 12:06 PM
my ss got a ls's Avatar
Default cold start question
I put a ls2 in my 86 montecarlo the cam I use is ground on a 110 I have cold start idle problems for almost to first min or so at start up but when the car is warm I have no problem at all starts instantly the tuner told me it was because of my cam but other people tell me that it can be fixed and straightened out by the tune
Old Apr 18, 2011 | 12:16 PM
KevinR's Avatar
Your tuner was wrong. It's all in the tune.
Old Apr 18, 2011 | 12:18 PM
Ok I thought so what areas should I look at in trying to get it right
Old Apr 18, 2011 | 12:44 PM
KevinR's Avatar
Wish I could help you on that, but I am by no means a tuner. I just know that I had the same problem when I did my cam install and my tuner got it all squared away quick. I'm sure someone will chime in and tell you what to check on, but honestly if you tuner can't get it figured out, you may need to take it somewhere else. What are the specs of the cam?
Old Apr 18, 2011 | 02:44 PM
SSpdDmon's Avatar
Sounds to me like a possible problem with where your IAC is at physically. If it's nearly maxed out with a high step count at warm idle, it will struggle to provide the necessary airflow required during cold temp starts. Your tuner should have done a thorough cold start tuning session, measuring desired idle airflow, and adjusted your throttle body set screw so that the IAC was in a "normal" position at running temperatures. If they didn't do that, find someone who knows how and will...
Old Apr 18, 2011 | 04:56 PM
I have a drive by cable so he drilled a hole in it to get it close to be where it suppose to be
Old Apr 18, 2011 | 08:01 PM
Slowhawk's Avatar
LS1Tech Sponsor
I would agree.
Only other thing is IF it is another TB (not stock) like a BBK or something they have an issue with too small of a IAC port which can definitely cause cold start issue's.
Old Apr 18, 2011 | 08:02 PM
SSpdDmon's Avatar
The IAC (idle air controller) is present in cable operated throttle bodies. Electronic throttle bodies adjust the throttle blade in place of an IAC.
Either way, it sounds like a possible airflow issue. Without a log, I can't say for sure. But, that's what it sounds like to me.
Old Apr 18, 2011 | 08:15 PM
minytrker's Avatar
Thats a sign to find a new tuner. I have never seen a car that needed the TB drilled to get it right.
Old Apr 19, 2011 | 03:42 AM
Originally Posted by Slowhawk
I would agree.
Thanks for the help you hit it on thce head if is a bbk I am thinking of switching it since I have heard it more than a few times
Old Apr 19, 2011 | 10:51 AM
So what is wrong with the bbk ones?
Old Apr 19, 2011 | 11:46 PM
Anybody want to let me in on the bbk throttle body
Old Apr 19, 2011 | 11:53 PM
Frost's Avatar
It's in the thread
I would agree.
